Not all assembly lubes clog filters some dissolve in oil, and if filters are changed regularly and are good quality a bypass is not needed as they should never clog.JoePorting wrote:Your oil filter is probably clogged up with assembly lube, which is why I don't like using assembly lube on new motors. I just use oil on new motors. I figure when you turn the oil pump on with a drill, you're just going to send all the assembly lube to the oil filter anyway, clogging it up.
Did you change the oil filter after the first 30 minutes of startup? That's a good idea.
Using a non-bypass oil filter adapter is also a bad idea IMO. The bypass is there for a reason. If your oil filter clogs up, the bypass will allow unfiltered oil into the motor. That sounds bad, but no oil from a clogged oil filter is worse than non filtered oil. I'd put the stock oil filter adapter back in.
But I agree, change filters after camshaft break in/first heat cycle, and I'd cut the filter open first too. Does it run an oil cooler, remote filter or something similar?
