randy331 wrote:LOL. Whatever you say.
Try this. Call the same cam company several days apart, with the exact same combo but different "flows" and then you will know exactly how "flows' impact cam specs. Then report back to us with your findings so we will all know too.
Then call several cam Companies with the exact same combo AND "FLOWS" and see how close they are. They should all spec the same cam since they all had the "flows".
I see you subscribe to getto scientific analysis. "Call the same cam company several days apart" Did you say off the shelf one size fits all?
or did you say go to autozone and give them a different symptom days apart and what do they try to sell you each time "Lucas!!" Do I need to explain marketing and incentive to maximize profit?
#1 marketing rule for a corporate salesman is to sell you what we have not what you really ask for and need. (not saying you can get a salesman that will if you request and give him the data will design and sell you a custom grind)
randy331 wrote:I disagree. I don't think gaining ex cfm on the flow bench is, any indication the ex port is better on the running engine. I've made ex port changes with no flow gain that increased the power of the engine. So what'd the bench tell me there?
And looking at just cfm on the intake side is no indication it will be better either.
And if you think having your "flows" in your hand when you call a cam grinder will get you the right cam the first time, your living in lala land.
I agree with what you disagree with If you take the small minded approach? But if you look at the larger picture of if you change the flow characteristics other items may need to be optimized to benefit.
Case in point you take a stock SBC 350 engine and put AFR 245's on it it will probably preform worse don't mater what cam grind you use. Leave the heads stock and use a better cam and wa-la you make more power. Does this prove your point?
Ok then put the AFR's back on, put an air gap intake with a 850 DP holly, the better camshaft, and 1 3/4 long tubes and you will probably make better power it may not be as drive-able but it makes more horsepower. Now put a more bigger more optimal grind and you will make even more power and maybe better drive-ability for what you purpose the radical engine for.
So minor changes in air flow may not require a different lobe profile but significant changes I airflow will benefit from a more optimal grind.
Does giving your AF #'s with all the other data guarantee a perfect grind not necessarily but you will get a better grind than if you give him no head data at all
