I think using CD would be much better than just cfm, but you'd need to know actual CSA of the valve window, and not just diameter x pi x lift. Calculating The true window csa would include seat angles/widths/back cuts/widths, and distance from valve edge to the chamber, etc.swatson454 wrote:I'm on that list as well, assuming the port isn't jacked up. I do believe, however, that Cd at low lift can be helpful in determining EVC and, thus, influence LSA.randy331 wrote:...but there others that read this and might, as in novadude and bigblocksontop2 for example seem to at least be entertaining the idea that flow bench cfm doesn't tell us much about an ex port.
Shawn
I should've worded that better. Actual low-lift flow at a reduced pressure is probably a better way to say it... maybe. First cup of coffee
That'd still leave out the errors of the higher depressions of the running engine, but it'd better.
