ON edelbrick and most heads it's time for a blueprint of the valves, stems guides, seats as far as fit and run out
new viton seals
know anyone with a Serdi or other modern valve machine
who does CNC on these heads?
Hotting up a 502 Crate
Re: Hotting up a 502 Crate
swatson454 wrote:Is there anyone in your area that can work them over for you?
Shawn
wyrmrider wrote:ON edelbrick and most heads it's time for a blueprint of the valves, stems guides, seats as far as fit and run out
new viton seals
Unfortunately not. Not that I trust to do more good than harm anyway... and if it where it is most likely VERY expensive. To the point that selling them to finance a new already done set of heads from AFR/Brodix etc would be a better idea.
I`ve been debating with myself about sending them to someone like scott foxwell and get a full job done with a matching custom cam package from Chris Straub. Not sure if that would be a better idea. Not cheap, but I`m pretty sure it would be a killer top end.
I like that plan
Shawn
Shawn
Live in such a way that those who know you but don't know God will come to know God because they know you.
Me too, not sure it is the cheapest way to 100 more hp though. I wrote Scott an email. Curios to see his reply.
On a sidenote; a friend of mine have the 620hp/572 from gm. I liked the spec on that cam, and seemed pretty spot on for what I wan't. Not sure if my lifters would handle that much lift though.
Vizard was commissioned to do some R&D on the 620hp/572 and the very first thing he did was change the cam. He knocked ~20* of duration off of their cam, tightened up to a 107 LSA and he's currently making more hp and torque than their race 572.
Shawn
Shawn
I like the way you think, Mr. Straub
Shawn
Shawn
From weight and mph I think I'm at 550-570hp now. And have not dialed in jetting or ignition yet.
Changing headers from 1 3/4 to 2" and adding a spacer might bring me pretty close to 600 hp already..
Question is how much will a custom cam add on top of that with my motor already being 11.2:1 instead of the original 9:1 (measured)
I think the cr would help somewhere around 40hp from stock?
