Pump gas 496 hyd roller build and dyno test
289nate
Re: Pump gas 496 hyd roller build and dyno test
Post by 289nate »
67RS502 wrote:
289nate wrote:
Bob Hollinshead wrote:Sure makes a GM crate 502 look silly. Would a good single plane intake make more HP on this combo? and how much?
Buy at least ten of them if he will build you one at the price of that crate engine. It's advertised in this thread as a 238* at .050 hydraulic roller dual plane intake 496 and very mild application. Do not confuse mild application with a mild budget.
I bet Marks 496 is about the same $ as a crate 502... all crate motors are way over priced for what parts they use, wrong comp. and low power, you'll get it all "right" with Marks BBC.
Agreed.
POS Dakota
Post by POS Dakota »
That is one outstanding build. Excellent work. =D>
vortecpro
Post by vortecpro »
"Yup, build an engine around a 3.08 rear gear and a regular old TH400? That's stupid and Vortech Pro knows it. But the customer pays the bills and you work for them."
"I just have to laugh at a guy who will spend this kind of coin on an engine and not change rear gears or the transmission. That has to drive a guy like the "Pro" nuts!!!"
Actually it was my idea to run the 3.08 gears, an excellent alternative to a OD trans when you have the power to pull it combined with a tight converter and a turbo 400, bullet proof I might add. Alan's 3720 pound fully loaded air conditioned 10 sec 3.08 geared driver Vette........
67RS502
Post by 67RS502 »
my new front runners (Goodyears) are 30lbs lighter then those Hoosier prostreet tires in the pic above.
we'll thy them next time.
67 camaro
girly rollers on pumpgas:
62 Nova cruiser
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
Orr89rocz
Post by Orr89rocz »
I'll second that. That much power will still yank 3.08 gears well. My turbo car on low boost is about 700 hp and never had a problem with 2.73's! Made for an awesome street driver. Now have 3.42's and its not quite as highway friendly as i like. Even with 27.4" tire
And i may be wrong but i think camkings recommendation in the one thread was a solid roller so figure 10-12 deg less for hyd and its somewhat closer to spec.
CamKing
Post by CamKing »
DA: 9490
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
briancb1
Post by briancb1 »
What's the seat duration?
I have a hard time believing you'll make 700 crank with that little cam with those heads.
Old Viking
Post by Old Viking »
I like the 3.08! Many years ago I had to go 3.70 in my Vette to run high10 sec at 130 mph! I dont want to hear the top speed running out of grear at 7000 rpm in top gear! Way to fast in the plastic fantastic.
Pls remember the combo as Iam planning to order one to my 4400lbs Caprice when I sin the lotteri! ;-)
As always a nice build by Mark. Wanted to hear of a small cam CBB build a long time.
Not to hijack, but is there still an IRS?
Burt
Old Iron Still Rocks
Keith Morganstein
Post by Keith Morganstein »
Some info and pricing are available on the website. Good values for the $ IMHO.
http://www.vortecproperformance.com/eng ... tions.html
vortecpro
Post by vortecpro »
Old Viking wrote:I like the 3.08! Many years ago I had to go 3.70 in my Vette to run high10 sec at 130 mph! I dont want to hear the top speed running out of grear at 7000 rpm in top gear! Way to fast in the plastic fantastic.
Burt
http://www.carsandparts.com/Articles/Co ... -s-vette-1
http://www.digitalcorvettes.com/forums/ ... p?t=130969
Best run to date: 10.59 @ 127.99 GM 049 headed, 238 @ .050 hyd roller, 9.8 comp, 496, 657 HP (Owen's dyno 902 Houston)
ptuomov
Post by ptuomov »
Sweet street motor with a very reasonable price. Makes me want an American muscle car.
Purely curious about the business side: Do you keep these motors in stock? Or are they built to order?
Put Search Keywords Here
289nate
Post by 289nate »
How much to build this engine carb to pan from scratch? Customer provides nothing but the coin.
I simply see an overdriven transmission and the rear gear it allows one to run as a serious rear wheel torque producer. Almost like a power adder off the line. Say you have 700 ft/lbs at the crank. The difference between a 3.08 rear gear and a 4.10 rear gear is over 700 ft/lbs. What would you pay to pick up that kind of torque where it counts?
vortecpro
Post by vortecpro »
I myself do not run OD trans, they are heavy, the converter is heavy, they rob power, they don't work the converter, and the 3.08 gear really makes the converter work. Now in my case Im all about 4.10 gears and 8 inch converters and 30X9 radials in my own street cars, (http://www.trracecars.com/4foot.jpg) but some won't have it, thats when I suggest the T400 with hiway gears.
Sorry I cant keep engines in stock, Im a one man shop.
722 HP 496, Intake to pan 9700.00
289nate
Post by 289nate »
Burt
With a 3.36 rear gear and fantastic weather.
D.S.R.E.
Post by D.S.R.E. »
Awesome results! You are the first builder ive heard other than myself that loves the TH400-3.08 gear setup for street instead of 4.10's and an od, most of the Pontiac engines I build love the load put on them especially when you are making 600tq by 3000rpm its a less expensive, lighter and more enjoyable package imho
Build it Once Build it Right!
