Pump gas 496 hyd roller build and dyno test
vortecpro
Post by vortecpro » Tue May 06, 2014 9:51 pm
After reading this thread viewtopic.php?f=1&t=37687 I thought I would share my 496 build. If theres any interest I would post pictures of the build. My goal is 700 HP 29.92 60 degrees dry air (STP), although the dyno test has not taken place yet. My build: 289 2 bolt block, 9.776 deck height, line honed, bushed lifter bores, .842, Mahle 15 cc piston, 6.385 Scat I beam rods unfinished, 2.325/.0008, Scat 4340 indexed, 4.249 stroke, M55 oil pump blueprinted, Moroso 20401 pan heavily modified, 238 @ 0.50 hyd roller, 109/105 .578 lift, billet core, Morel lifter, 3/8 .083 wall pushrod, Scorpion 1.7 rockers, Modified AFR 265 heads, 170/400 spring pressure, Modified performer RPM air gap, 1000 AED 4150 carb, 1 inch open carb spacer. 2 inch headers, 3 inch mufflers, MSD 85551 dist, MSD 7AL2, 91 octane Shell gas.
Bob Hollinshead
Re: Pump gas 496 hyd roller build and dyno test
Post by Bob Hollinshead » Wed May 07, 2014 12:28 am
Post up some pics! Reading that old thread Cam King said it would take a cam of 260@.050 to make that kind of power and that's a long way from 238@.050! Isky cam in this one?
Pro question poster.
496blaze
Post by 496blaze » Wed May 07, 2014 12:42 am
Mark, did you bush the lifter bores to correct geometry issues or was it to get the proper clearance? Maybe both..
vortecpro
Post by vortecpro » Wed May 07, 2014 9:17 am
496blaze wrote:Mark, did you bush the lifter bores to correct geometry issues or was it to get the proper clearance? Maybe both..
The block had rust in the lifter bores, which would have left excessive clearances.
The "Cam King" very well could be right.
After all that Isky 238 lobe is such an aggresive valve opener :lol:
I still would like to see the Cam King and Joe taking their daily walks together though. :shock:
67RS502
Post by 67RS502 » Thu May 08, 2014 1:27 pm
cant be done with a 238 cam
just like runnin 10s with a 224 cam
never happen :lol:
I'm interested in seeing the build
what the comp?
waitin on pics of the oil pan :D
have you tried more wall thickness on the P-rods? or no diff because of the mild lobes?
and I'd love to see 3 1/2" collector extentions compared to the 3" muffs... or would that make a diff with higher acceleration rates?
67 camaro
girly rollers on pumpgas:
62 Nova cruiser
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
stokerboats
Post by stokerboats » Thu May 08, 2014 5:10 pm
I'd also like to see pic's of that oil pan. :D
vortecpro
Post by vortecpro » Thu May 08, 2014 9:32 pm
Dan and Raf I will make sure you guys get your pictures. Compression came in at 10.5. The first thing were going to get into is how the SF 901 dyno is calibrated and tested for calibration. It will be good information.
qtrmiler
Post by qtrmiler » Fri May 09, 2014 1:00 am
Just to be sure you need to check the oil pump part number. The m55 is a std volume sbc pump. Hopefully a mispost, but be sure you don't install it if it is the pump you have selected. Because you will have trouble with the pump shaft being the incorrect length, the pickup tube will be restrictive being 5/8" instead of oe bbc size of 3/4" and the sbc pump won't supply enough oil without cavitating the oil.
Thomas
Old School
Post by Old School » Fri May 09, 2014 1:05 am
vortecpro wrote:Dan and Raf I will make sure you guys get your pictures. Compression came in at 10.5. The first thing were going to get into is how the SF 901 dyno is calibrated and tested for calibration. It will be good information.
Do we have to request the pictures of the oil pan or are you going to post for all to see?
vortecpro
Post by vortecpro » Fri May 09, 2014 7:58 am
Here you go.
67RS502
Post by 67RS502 » Fri May 09, 2014 12:17 pm
thanks
that gives me an idea on what to do, I thought the sump may be closed off more then that. guess its a balance between oil return to sump.
hope it will help a car that 60fts at a snails pase :)
next time the 420 comes out I will be welding on the pan "some more".
dyno calibration... thats over my head, but I know you got it right, and its and honest dyno.
also Mark likes his oil hot and water cold 8)
67 camaro
62 Nova cruiser
224/224 HR cam
1.57 10.97 @ 121.2
Wolfplace
Post by Wolfplace » Fri May 09, 2014 12:30 pm
67RS502 wrote: also Mark likes his oil hot and water cold 8)
You sure you don't have that mixed up with woman & beer :mrgreen:
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
vortecpro
Post by vortecpro » Fri May 09, 2014 9:34 pm
Some pictures of the setup.
Air turbine calibration: 304.2
Filter: 3
Baro: 23.52
DA: 9490
Fuel weight: .759
Bore: 4.310
Stroke: 4.249
vortecpro
Post by vortecpro » Sat May 10, 2014 7:32 am
496blaze
Post by 496blaze » Sat May 10, 2014 11:11 am
Mark, first of all thank you for taking the time to share your expertise. I learn a lot by reading your posts. I am wondering if your modified 40203 pan will use an additional windage tray or crank scraper or simply the run with the mods shown. Also was it a typo or are you really running a small block oil pump?
