Popular cam companies / designers
joespanova
Post by joespanova »
I'm getting old and can't recall all the names........I'm possibly in the market for another cam and need names to contact.
Bullet
LSM
Crane
Lunati
Comp
Who am I missing? I need a little more power............
In case your wondering my current cam is 276 / 288 .........760 /.750 and is a drag race 355 running 9.50s - 9.60s @ 139 and change @2900 lbs...............I need 15-20 more HP
modified wanna be
af2
Re: Popular cam companies / designers
Post by af2 »
Joe, why would you not go with a custom cam grinder that is less than buying a cam from the BIG companies?
GURU is only a name.
Krooser
Post by Krooser »
dirtracr5
Post by dirtracr5 »
woody b
Post by woody b »
9.50's @2900 pounds with a 355 is stout if NA.. I doubt you'll get 15 to 20 horsepower with a cam change. Good luck.
Smell Ya Later
Post by Smell Ya Later »
Just talked with UDHarold (Harold Brookshire) last week, sharp designer. 662-562-4933
wyrmrider
Post by wyrmrider »
Have your head flows handy
What's your installed height?
rockers?
rev kit?
joespanova
Gentleman , thank you.................I am open to any reputable cam grinder / designer , large or small co.
My heads are 23 degreee Brodix , ported by 2 different porters ( LOL ) the original Porter and then Larry Meaux , who "tweeked" them recently.
And yes , the engine is normally aspirated with a tunnel ram.
modified wanna be
randy331
Post by randy331 »
wyrmrider wrote:Have your head flows handy
Why? For specing a cam ?
If someone thinks they can spec your cam based on flow numbers,..I'd use someone else.
engineguyBill
Post by engineguyBill »
Head flow info is one of several parameters that are taken into account when determining the correct cam for a specific engine combination.
Bill
SAE Member (30 years)
randy331
Post by randy331 »
engineguyBill wrote:Head flow info is one of several parameters that are taken into account when determining the correct cam for a specific engine combination.
So your telling me a sbc with dart pro1s flowing 300 cfm needs a different cam than one flowing 310 cfm all other parameters the same?
If so,...which one needs what changed?
joespanova
I dont know if it would make a difference..........I think they just like to know what you are working with.
modified wanna be
lorax
Post by lorax »
If a cam designer DIDN'T ask for the flow numbers, I'd be looking somewhere else.
Its not JUST the max flow numbers, its the entire flow curve.
From the top of the carb to the valve face is important info. Not knowing the head flow is paramount to not knowing the engine size.
ErsonCamShop
Vendor
Post by ErsonCamShop »
We would be glad to assist you. You can reach Eric Bolander at 800 641 7920 ext 8003. We are a small company and have recently moved from Carson City, Nevada to Louisville, Kentucky. We've been here since October of 2011. The manufacturing facility is under new management since the move. We campro and inspect every cam. We strive for quality, precision and craftsmanship in every cam we grind. We don't want to be the cam company that produces 10,000 cams a month; We want to be the company that produces the best camshaft on the market. We welcome any feedback, positive or negative, because feedback is what is going to make us grow and help us to produce the highest quality camshafts on the market. We can gladly custom grind anyone a camshaft to best meet the specifications to make their engines as efficient as possible to produce peak horsepower.
Thanks
Russ, Facility Manager
Russ Yoder
Erson Cams
Louisville, KY
ersoncamsshop@gmail.com
www.pbm-erson.com
800-641-7920
ext 8003 (John)
ext 1041 (Ryan)
F-BIRD'88
Post by F-BIRD'88 »
You missed Isky Racing Cams.
www.iskycams.com
