It took about 12 reads to understand what this guy was saying. I THINK I have it right…Krooser wrote:I also asked this same question at a circle track forum. One member there posted this answer to my question… very tuff to read and understand but….
"After using a vacuum advance and only the best spring controlled weights to aid in hooking up with less horses for a few feet in order to be able to floor the car while sideways and it moving, I addressed the potential of hotter fire and more fuel! While burning twice the fuel that most use all night just in a 20 lap race with the plugs still snow white, I figured out that hotter fire allows for a boost in horses if you can put enough fuel in to match! Sure we wasted a few parts getting to that point but the horses was out of the gate! You can't turn back after being hooked and everyone is looking for the Nitrous on the car! Intakes were pulled! Fuels were sent off for testing! Tachs were disconnected! A stock GM module and coil with a tan cap and rotor that puts out more than you can believe! More than we could buy! A 10 degrees block on both vacuum and weights giving a 20 degrees advance total was used! Bench testing on 12 volts it would jump from pin to pin with out any plug wires on the cap easily! Test yours and it most likely just clicks inside or jumps to ground at the coil! Getting it to the plugs does require a good set of tan parts and wires to say the least! A Rocket 350 GM OLDS coil from a early year with a .080 plug gap was used! Jets must be changed before hot lapping and a constant check on the wet oil of at-least 3 threads on number 3 cylinder to keep from going lean and melting plugs, head gaskets or burning the block and heads in three laps! Proceed with caution as not to be shocked or trampled in the process of these extra horses! Set the timing with the engine at 5,000 rpms without vacuum hooked up! Be sure to use a live vacuum port or it will not fall back to the weights while on the throttle! I run no power valve in my carbs ( blocked and up 5 jet sizes more, 83-86s on a two barrel) and a cool 150 degrees engine temps to allow more air to flow as well! Work your way up on timing and fuel to get more horses with the extra fire power! No racing fuel used, just 93 pump gas! Hope you find more than you expected and then some!"
Read more: http://thedirtforum.boards.net/thread/4 ... z2yxY8L4sf
He sez run 20 degrees initial… with 10 more vacuum and another 10 in the mechanical advance. Lots of fuel… 83-86 jets in a 4412 with the PV blocked. 150 degree water temp. The theory here, if I have it right, is to use the vacuum advance as a sort of 'traction control' keeping the engine down on power until the final 10 degrees of adv. comes in near the end of the straightaway… keeps the driver from blowing off the tires on a slick track.
Plus he advocates using the high voltage coil (Olds 260?)…
Has anyone used a 5 pin HEI module and used the 'r' terminal switched to ground for a 10 degree retard for easier starting?
Interesting stuff...
