header collector question
jacksoni
Re: header collector question
Post by jacksoni »
--- Header Collector Specs (Conventional Straight Tube) ---
Diameter= 3,278 Tuned Lengths= 17,9 best and 9,0 or 35,8
3rd Harmonic = 35,8 inches long ... more bottom-end Torque
4th Harmonic = 17,9 inches long ... highly recommended , best Torque Curve
5th Harmonic = 9,0 inches long ... reduced Torque , more top-end HP sometimes
Belgian1979
Post by Belgian1979 »
jacksoni wrote:--- Header Collector Specs (Conventional Straight Tube) ---
Yes, the 4th harmonic was what made me think about it.
jacksoni
Post by jacksoni »
For street car you should be looking at the total length:
-- Total Exhaust System Tuned Lengths (Primary ends to TailPipe end) --
Best HP/TQ Tuned Collector Lengths= 17,9 , 35,8 , 71,6 , 143,2 inches long
So 143.2 or double that.
Belgian1979
It's 149,06" from cyl 1 to tailpipe.
Post by 1989TransAm »
Belgian1979 wrote:Actually from where and to where do you start measuring your collector ? I started from the end of the primaries to the flange.
Does your collector have a cone/spike in it. If so you need to take that into account.
Belgian1979
No, it's just a plain jane older header. Four pipes welded in a collector. The center is welded shut.
swatson454
Post by swatson454 »
jacksoni wrote:For street car you should be looking at the total length:
Unless you can find a reasonable means to separate the tuned length from the rest. Is a terminator box or an empty muffler case possible on your car?
Shawn
Live in such a way that those who know you but don't know God will come to know God because they know you.
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
Every one is really OVER THINKING this this topic real bad-- On full street exhaust set ups, there will be very little or NO DIFFERENCE. SORRY
JOE SHERMAN RACING
hoffman900
Post by hoffman900 »
bigjoe1 wrote:Every one is really OVER THINKING this this topic real bad-- On full street exhaust set ups, there will be very little or NO DIFFERENCE. SORRY
JOE SHERMAN RACING
It matters in road racing and circle track applications where requirements are similar (past the driver and have to meet noise regulations).
For full exhaust, assume the collector extends to atmosphere... so you're looking at the entire tailpipe length.
-Bob
Post by MadBill »
2X
Unless steps are taken to 'de-couple' the rest of the system from the collectors (e.g. with Vizard-style terminator boxes) the engine will experience a very different tune than projected by an open header calculation. E.g., if a 9" or 18" open collector tunes perfectly for your application, putting a tapered adapter on the end and necking it down to 2-1/2" for the next 4 feet then running it through a muffler changes everything. If the system continued at 3" into an open can (e.g. Flowmaster type) muffler, then if the total length matched one of PipeMax's alternatives it should be pretty well set.
Belgian1979
What is a terminator box
digger
Post by digger »
on a dual exhaust street system for a 250 bhp inline 6 i saw huge losses right at the bottom end (10%), in midrange (12-14) % and peak (10%) simply moving the x-pipe too close to the engine (from 550 mm from end of primary to 400 mm from primary). the AFR were a lot richer (until tuned) indicating the lower airflow through the engine but the engine seemed to not nose over as fast.
the twin system has a catalytic converter, resonator for each pipe and then a dual in and out muffler (not sure if the pipes are linked inside the muffler) complicating what is going on.
at some point i'm thinking i will run a y-pipe positioned at the 3rd harmonic (800mm) and run a simpler single pipe system
Post by MadBill »
Belgian1979 wrote:What is a terminator box
There are a number of detailed threads here on S/T under the search term 'terminator box', but briefly, it is a large volume empty exhaust chamber or open Flowmaster-style muffler fitted to the end of the tuned collector, upstream of the muffler and tailpipe, that tricks the engine into 'thinking' the system is wide open. With a properly designed system, even very high power engines can see less than a 1% power loss vs. true open headers.
If using two termination boxes each has to have a volume at a minumum the displacement of the motor to be fully effective.
Belgian1979
wow that is quite large. There is no way I can fit something like that under there.
So based on the comments I assume that there is not going to be any use to an extended collector.
