Barry_R wrote:As for the emissions commentary...
Holley had to meet the exact same pollution and mileage standards as did any other OEM carburetor application in a given year. The EPA and CAFE did not care who supplied the parts - the rules were the rules and all manufacturers had to meet them. The drivability aspects are in the eyes (or behind) of the vehicle manufacturer and/or owner, but I can scarcely imagine Ford being all that much less demanding than GM.
I was always kinda surprised that they assigned a complete new series to the 4180 since it is very much a refinement of the traditional 4160 carbs. It has annular booster on the primary side, some interesting metering refinements, and some emissions driven details. But Holley had made many larger scale changes to carbs in the past and just assigned new list numbers (look at a governed 4150G versus a 4776 double pumper...). Must have been desired by a marketing or sales decision at the OEM level.
Barry ... maybe I can show some light about that 4180; I was part of that project for OEM intent, (not any aftermarket production).
The 4360 carb was supposed to also be for an OEM on a V6 but, it got shelved and the aftermarket brought it to the marketplace. A GREAT metering carburetor of spread bore design however, a bit small in CFM, (I believe 460 CFM), to really catch-on in that venue, (with small secondaries similar to the primary side). Mechanical secondary operation but, it NEVER "bogged" so, it only needed one long duration piston type accelerator pump.
Back to the 4180. It had completely different primary circuits, (not simply a change or refinement of anything previous), which designated a model number change though they shared many other design features with the 4150/4160 models; (kinda similar to the 3160 3 barrel carbs change in model number because of a completely different secondary metering design).
What most people could see was that the idle mixture adjustments were now in the throttle body instead of the metering block and the main circuit had a totally brass main well insert with differing emulsion holes and locations. the design was "emissions driven" and produced a MUCH better acting "part throttle" carburetor with leaner settings.
AND, they were installed all the way into the early 90's on some heavy trucks. The 4180EG was an electric governor carburetor used in the OEM manufacture of many heavy truck fleets with gasoline engines..
