lorax wrote:
The fuel wash never allows the carbon to develop to start with.
I respect your opinion Lorax, but then I wonder how intake ports sometimes get sooty due reversion? The constant fuel flow there would keep the walls clean right?
Looking at the chamber pic again, its suggest the majority of the intake charge is following the shortest path to the depression path (spark plug side of the of the cylinder,or exaust valve seat due overlap suction) like we do know it should, then I believe the fuel is being almost totally directed to the center of the chamber due the fact the valve windown is also much bigger there than the valve to chamber wall windown.
The carbon indicate where in the chamber the "raw" fuel is being deposited by the intake charge and due the lower chamber wall temperature needed to combustion (hopefully), after the spark, this same fuel is partially burned and partially "melted" on the chamber building carbon.
Sorry I haven't chemical base to explain why this happen or if even correct. JMHO again
I'd luv to learn more about this also.
