Could you copy and paste my quote where I said I run my lifters in water??ParDeus wrote:So you run your lifters in water? Interesting...CNC BLOCKS wrote:So that would work in a marine application where water temp is under 145 degrees HMMMMMMMMParDeus wrote:I will defer, as to not muck this thread up anymore.
Horsepower tip: Sizing your lifters/bores at 210degF
Also, the right finish on spring seats can help high rpm apps live a little longer. Also make sure your retainers/locks fit properly. Profiling to gain contact area is usually needed.
You know the oil/block temp can greatly vary from the water temp, right?
210 is not a perfect temp, but it is enough to show significant distortion. Like hot plate valve jobbing; It's not at the actual operating temp, but it's better than 65f. Similar, again, to setting hot lash. It is only a guesstimate, because doing so at operating temp is either impossible or not economical.
I second the previous poster who mentioned a slight offset in head positioning. That, in conjunction with the right head gasket.
You never answered my question
Just comparing apples to apples here LOLI am a guy with a few machines as you say so what do have for machines???????????? Back at ya.
