Kevin Johnson wrote:SchmidtMotorWorks wrote:
Kevin, you live in a fantasy dream world.
Please feel free to provide interviews with GM pattern makers from the 1970s who designed manifolds. Really, it would be interesting.
Now, my "dream world" consisted of consulting with a Cosworth Engineer who explained the degree of freedom that pattern makers have with castings and allowable variations. He worked with Danielson when I spoke with him. Do you need his contact info?
http://www.danielson-eng.fr/en/
Here's an example. Gate variation in Zetec E sump castings. In the picture of eleven sumps with the same part numbers there are four distinct variations introduced by pattern makers.* They are separated by group in the picture.
* A second set of variations was surface or casting finish.
My friend, Jean-Claude, was in the Porsche factory in the 1950s, as well as the Renault factory and was an engineer for Matra. We had many discussions about common practices.
Look, your technique clearly works 95% of the time. You should be happy with that and not be so troubled by people who can call you out. Maybe some more sims will help.
You are off in left field, the post was about SBC single plane manifolds made by the after market in the USA. They are not designed by OEMs.
Cosworth has zero relevance.
The technique I describe isn't my technique, it is how it was done.
By the way, Cosworth uses the software I develop to design engines.
Most of the patterns that were made for aftermarket manifolds in the 60s, 70s, 80's and even 90's the the USA, never had any drawings made for them, there really wasn't any point to it.
It usually went like this, you bring a hand sketch or describe to a to a pattern maker what you want that cuts out the cores and pattern pieces from mahogany on a band saw and files them to shape.
This isn't a guess on my part, I have seen about 75% of the patterns as almost every US after market casting is or was cast at the same foundry at one time or another.
One of the few patterns that had drawings were the Offy stuff, but the drawings are so crude and incomplete, the pattern maker didn't have much to follow and the fidelity is rather approximate (they didn't even have draft on the drawings).
