The graph posted earlier shows crank angle (deg), piston air demand (cfm), valve lift (in), curtain area (in^2) and flow velocity (ft/sec). The engine bore = 4.0", stroke = 3.25", cr = 6.0", valve dia = 2.0", rpm = 7000, inlet duration is 280deg (seat to seat).Stan Weiss wrote:I have posted this for David Redszus. Who will add commentary about the post.
Stan
At TDC, the valve lift is .139" (25% max lift) but there is no piston air demand since there is no piston motion. The only flow that can occur is due to pressure differential of inlet and exhaust ports.
Maximum piston air demand (537cfm) occurs at 76 deg ATC as does maximum piston speed. The valve lift is .555 (90% max lift). Flow velocity is 521 ft/sec.
Maximum valve lift occurs at 113 deg (.614") but piston air demand has fallen to 428cfm and velocity has also fallen to 453 ft/sec. Less air is flowing into the cylinder at maximum valve lift.
Note the dip in the velocity curve and that only the curtain area curve follows the valve lift curve.
As Mike Jones indicated earlier, the proper selection of the camshaft, based on piston air demand, rpm, and valve size can substantially improve the air flow into the engine. Or an improper cam can have the reverse effect.
Thanks for posting the graph Stan.
