ptuomov wrote:Chrysler engineers call the driver side the suction side and the passenger side the pressure side. The small suction is generated by the rotation of the crankshaft.
Kevin Johnson wrote:I think it is more related to the deliberate offset of the crankcase volumes in many engines. Study the designs more and from more companies. The diffuser area allows pressure to build. Look at the Mopar Slant Six for example. A V8 greatly complicates this but many high performance V8 pans still rely on the diffuser concept (large asymmetrical kickout).
I disagree. In the simulations, the suction effect shows up even with a symmetric crankcase and oil pan and symmetric windage tray with simple symmetric holes.
It's either the crankshaft rotation directly or the one-two piston pumping pulses in which the passenger side piston serves the gas to the driver side which the punches it out. A bit like a one-timer in ice hockey. Regardless, it exists in a perfectly symmetric crankcase.
ptuomov wrote: According to Chrysler simulation, their new 6.5L engine that is vented from the valve covers flows gas up continuously on the passenger side oil drains, while the direction of the gas flow in the driver side oil drains fluctuates with the engine cycle. As a side note, for a 6.5L V8 at 6000rpm, the piston pumping pulses are the elephant in the crankcase and the gas flow patterns due to crank rotation are of second order compared to piston pumping. This may be different for a small four banger, just talking about big V8's here.
Kevin Johnson wrote:With something like the Maybach HL 210 with directly opposing piston banks the crankshaft rotation would be less significant. With offset banks like in the Porsche V8 or Ford Modular V8 the rotation is highly significant in setting up flow patterns.
I don't think the bore offset is significant. It's 25mm in Porsche 928, and less in most other motors. One could hypothesize that the bore offset causes a circular movement within a single bay. In the simulation data, though, the overall pumping movement completely overwhelms this effect. When the opposing piston sucks or pushes, the flow is in the same direction on both sides of the bay. The simulated flow thru the bearing side breather holes also doesn't support this theory. It's a good theory, but I don't think it's actually true if we limit ourselves to large-displacement 90-degree V8's.
Now, in an inline four, we probably see two simultaneous circular motions, one in bays 1&2 and another in 3&4, but that's a pure guess on my part and not based on any actual simulation data. But I could see that happening.
ptuomov wrote: I've also come to the opinion that it's not a productive exercise to try to get any scrapers as close to the crankshaft as possible in a big V8. The pressure differentials directly caused by the crankshaft rotation are not very significant.
Kevin Johnson wrote:Yes they are when the average droplet size allows gas flow to predominate in influence. This is not controversial.
I fail to see the relevance of droplet size here. Quantitatively, the gas flow caused by piston pumping is the elephant in the crankcase and everything else is a bunch of mice.
The below figures are from the simulation data set run with an asymmetric windage tray. The color coded velocity vectors indicate the speed at which gas flows at that point. Here's a cross-section of the front bay at 315 degrees on the crank:
You can see a minor effect of gas flowing with the crankpin near the crankpin. But you have to squint. The elephant in the room is the driver side piston unleashing the fury.
Below is the same bay at 225 degrees, 90 degrees earlier than the above graph. Now it's relatively calm there, so you can see the crankshaft rotation effects a bit more clearly. But it's still very minor compared to the piston pumping effects.
This with the caveat that these observations only apply to big 90-degree V8s. A small four banger might be a completley different story. As a side note, it seems to me that car factories use scraper-style devices more in small four bangers and less in big 90-degree V8s. But that's just a casual impression, you would know better.
Kevin Johnson wrote:Scrapers function differently at different RPMs. The flow allowed into the vortex in the Coyote valley feeds reduces the pressure differential and reduces the equilibrium level of oil droplet entrainment. A scraper approaches this task externally.
I agree that everything is different at low vs. high rpms. Gas flows aren't an issue at low rpms. More generally, as far is this site and audience goes, what happens at low rpms is pretty much irrelevant. There are no problems to be solved at low rpms, at least no problems of significance to this speedtalk.com crowd.
I enjoyed your Coyote writeup, by the way. After spending time with these simulation data, I would have approached that windage tray modification differently, however. Ford came to you saying that they lost power with the windage tray, and wanted to fix that. I would have fixed it simply by making the holes in the tray larger. You chose to fix it by adding more devices in there that restrict gas flow. I have no data on what your approach produced in terms of picking up the lost power. However, I conjecture from these simulations that the number one determinant of the power losses with the windage tray is the size of the holes. I have simulation data from a similar engine that says that larger holes add power and smaller holes reduce power, and the effect is significant. I also conjecture that stuffing the crankcase with more things that inhibit flow will increase power losses, not reduce them. That's just a conjecture.
Just an opinion, but I believe an informed opinion. if they sent you dyno data with your modified tray, it would be very interesting to see that.
ptuomov wrote:If the scraper blocks the piston pumping pulses, the losses are likely a lot bigger than any benefits in reducing the crankshaft rotation pressures. The one thing that I think scrapers can help with is preventing oil from rebounding back to the crankshaft, and for that purpose it's much more important to get the scraper angle right than get it very close to the crankshaft. On a small four banger, this may also be different, just talking about big V8's here.
Kevin Johnson wrote:Directional screening is iterated scrapers. If the mesh size is appropriate it can be helpful in stopping droplet bouncing which tends to lead to droplet size reduction and greater oil entrainment. Ford did sponsor empirical testing of windage tray designs on a V6 at MIT. I think we have been over that a few times over the years. Some errors in the experimental design and analysis lead to recognizing both dedicated scrapers and well designed windage trays as being important.
The car factories seem to hate those screens that you love. I don't know if this is for cost or reliability concerns, or if they have issues with performance.
My casual observation is that the aftermarket performance market is also moving away from mesh screens and towards solid trays with larger openings. I don't know if this observation is correct or not, but that's the impression I've gotten.
