ClassicComp
Posts: 933 Joined: Mon Jan 23, 2006 10:50 pm
Post
by ClassicComp » Sat Oct 19, 2013 12:48 pm
Ok it"ll run 11.99. I have a 460hp sbc in an 80 vette that turns 115mph with 11sec et's in street trim. I doubt you'll have a problem as is.
results speak for themselves
mvette76
Posts: 35 Joined: Sun Apr 18, 2010 8:19 pm
Post
by mvette76 » Mon Oct 21, 2013 5:45 pm
got the cam ordered today can not wait to see what this motor will do in my little vette
myratsabeast
Posts: 1 Joined: Sat Oct 19, 2013 6:48 pm
Post
by myratsabeast » Tue Oct 29, 2013 6:19 pm
Better not beat my Chevelle! (I'm his cousin) but I could live with a neck n neck tie hahahaha!
I need to find a way to even remotely hook on the street with my Vortechpro 496 or the much
Better balanced Vette's going to scoot right on past me
mvette76
Post
by mvette76 » Tue Oct 29, 2013 8:34 pm
I don't think you have any worries! my firestones on the other hand
mvette76
Post
by mvette76 » Mon May 19, 2014 8:14 pm
a little update on this build! put the big block on the dyno finally and the numbers are 567 hp @ 5800 576 tq @ 3800
496blaze
Posts: 69 Joined: Sat Feb 10, 2007 1:45 am
Post
by 496blaze » Mon May 19, 2014 11:30 pm
What cam did you end up using?
F-BIRD'88
Posts: 9819 Joined: Tue Mar 27, 2007 6:56 pm
Post
by F-BIRD'88 » Tue May 20, 2014 4:29 pm
mvette76 wrote: a little update on this build! put the big block on the dyno finally and the numbers are 567 hp @ 5800 576 tq @ 3800
Good stuff
mvette76
Post
by mvette76 » Tue May 20, 2014 6:19 pm
its a clay smith cam from straub technology
•Part. No.160-3106
•Adv. Dur 292/302
•.050” Duration233/243
•.200” Duration152/158
•Lift .620/.600
•Centers 103/111
•LSA 107
mvette76
Post
by mvette76 » Sun Jul 16, 2017 8:29 pm
I'm thinking of pulling this BBC apart over the winter and changing pistons and heads to afr cnc 265 leaving cam and possibly a Vic jr. Intake would I gain enough to justify the heads?
vortecpro
Posts: 1799 Joined: Fri Apr 24, 2009 11:10 pm
Post
by vortecpro » Sun Jul 16, 2017 10:44 pm
mvette76
Post
by mvette76 » Sun Jul 16, 2017 11:00 pm
What are you trying to tell me? I remember that thread and I'm pretty close to his power now
Bob Hollinshead
Posts: 1481 Joined: Thu Feb 07, 2008 1:32 pm
Post
by Bob Hollinshead » Mon Jul 17, 2017 7:09 am
I don't think Mark likes using single planes much with his oval port combos
Pro question poster.
vortecpro
Post
by vortecpro » Mon Jul 17, 2017 8:00 am
mvette76 wrote: What are you trying to tell me? I remember that thread and I'm pretty close to his power now
You should be able to reach your goals.
mvette76
Post
by mvette76 » Mon Jul 17, 2017 12:43 pm
The vette runs strong no dought about that I've only had it at the track once since the swap and it something like 8.0@92 if I remember right that was with a 3310 Holley it now has a 850 Holley hp ultra and I had my old mans marching number transmission to his 66 vette in it so I was trying to be gentle now it has a tko 600 and side pipes! The thing that bugged me about the build when I did it was the vast iron heads so the hole purpose of this thinking is loose weight with aluminum heads and maybe gain a little to hit the 600 mark
