You still seem to be trying to tie pump speed and volume to pressure that activates the relief.Belgian1979 wrote:Kevin,
It was explained to me that the linear line before 2000 engine rpm is the volume displacement of the pump, above 2000 rpm in that graph the bypass seems to kick in (graph going flatter). If you take the gpm at say 600 engine rpm and you multiply by 10 for 6000 rpm, it would be a fair assesment, since the teeth displace the same volume but they turn faster (all other variables ignoring). However, even with 22 gpm the pump output should be sufficient against the backpressure in the system to reach the bypass setting. I cannot believe the engine would warrant 22 gpm not even on high rpm.
We're getting a bit off topic, but there is a possibility that this would not provide the solution. If that's the case I think the only viable option would be dry sump. Right ?
I don't know if the cooler is still in line, but consider this, If the cooler and all its lines and fittings, plus the pressure drop across the filter have a fixed volume they can pass at a given pressure, say 75 psi. and your engine requirements EXCEED that volume, the pressure relief in the pump side can activate even though the oil pressure in the block is dropping like a rock. The pump is pushing as hard as the relief will allow, but the engines volume requirement climb with RPM, and the cooler line and everything else are acting as a volume restriction between the two.
If the cooler is suitable for a go cart, the pump can only do so much to push oil thru it because it has a pressure regulator.
