Avgas is not "dry". A better description is "clean". You think it is "dry" because it does not leave an oily residue when it evaporates, like pump gas and many race fuels. Avgas is intentionally designed, refined and blended, to not leave deposits of a harmful nature in the engine. Other fuels leave an oily residue which eventually oxidizes and forms gum that burns to form carbon deposits and causes sticky rings and valve stems. For obvious reasons, such as walking home from 15,000 feet up in the clouds is no fun, aircraft engines must avoid problems which would only be a minor inconvenience in an engine on the ground, or even in a boat.levisnteeshirt wrote:the term we've always heard around here is that avgas is " dry " , a small amount of 2 stroke oil or marvels helps this ,, if you know of something better , by all means
Again, Avgas is not "dry" ....... it is "clean".
Do not add anything to Avgas except an octane booster which contains MMT if you need higher octane than 112.
Do not add oil, 2-stroke or otherwise, unless you are using it in a 2-stroke engine which requires oil in the fuel.
