GLHS60 wrote:I don't have much experience with 250's but surely you're joking about a U-joint on the distributor...aren't you??
Thanks
Truckedup wrote:Sloppy GM core shifts and machining is nothing new.I was building a 50's GMC 302 inline 6 for performance. The lack of stamped numbers meant this was a replacement short block.The standard bores were off their centers,the block deck tilted side to side and front to back,the connecting rod centers varied about .006. But the main bearing bores were perfect....The engine will function as intended ,but.......
The last years of GM 250 inline engine had an HEI ignition.Many of the HEI's have a U joint on the shaft. A U-joint? A GM power plant engineer told me the machining was so sloppy the distributor bored hole was cocked causing warranty issues with worn distributor bushings.The U joint was an easier fix than trying to get the tooling sharpened and set up correctly.
I heard that it was common for GM to use dull or poorly set up tooling .These orders came from management trying to save a few cents. I'm sure the other auto makers did the same but GM was the biggest so it made more sloppy stuff.
U/joint in the dist. shaft you bet.
There was a ton of them engines that failed a cam or dist. gear on a regular basis and I have seen the split shaft thats pinned to for a u/joint.
We make our own lower shaft for the 6cyl. class's that run the 250 engine as there is so much misalignment of the cam gear and dist. gear they wear out in no time driving a std oil pump above 3000 rpm
