536hp 347
FloydODB
536hp 347
Post by FloydODB » Fri Jun 14, 2013 8:53 pm
i need to thank everyone for their help and contributions.
Joe for the inspiration and guidance
http://www.enginebuildermag.com/Article ... build.aspx
the same for others on this forum wiser than I. [-o<
Mike at jones cams
Dick Mceldowney at mid America motorsports
Rich Farnsworth,Jim Kubash,Mike McKenzie and Mike Zordon from Lane Automotive
and most important, God. (especially for the great weather today)
10:1 347ci ford. scat forged crank,I beam rods, SRP Pro pistons, melling (STOCK) pump, canton pan and windage tray, power bond damper, engine pro timing chain,comp cams lifters, JONES SOLID ROLLER, engine pro push rods,AFR 195 heads(UNTOUCHED!!!), T&D sport comp shaft rockers, port matched vic jr. with (blended plenum)Crane distributor/ps60 coil, 750qft crab, 93oct BP, brad penn oil, wix filter.
wont give the cam specs so dont ask! ill tell you that its SMALLER than Joe's. no offense Joe.
536hp @ 6800
475lbs @ 5300
over400 lbs from 3300 to 6900
over500hp from 5600 to 6900
bsfc were mid to low 400's throughout and rich at throughout.
might not be out of this world to some but its the most hp/cube I've done!
very happy customer Mike! Thank you!
Daniel Brown
Accurate Engine Rebuilding
(269)930-1962
swatson454
Re: 536hp 347
Post by swatson454 » Fri Jun 14, 2013 8:59 pm
Excellent! Especially your reference to God. That's pretty rare these days. Congrats on a fine build =D>
Shawn
Live in such a way that those who know you but don't know God will come to know God because they know you.
bigjoe1
Show Guest
Show Guest
Re: 536hp 347
Post by bigjoe1 » Fri Jun 14, 2013 10:52 pm
Looks like you had a good recipe to follow.That was a long time ago.
JOE SHERMAN RACING ENGINES
289nate
Re: 536hp 347
Post by 289nate » Sat Jun 15, 2013 12:09 am
That is a nice spread between peak torque and peak HP. Well done!
needforspeed66gt
Re: 536hp 347
Post by needforspeed66gt » Sat Jun 15, 2013 12:45 am
Is there a specific reason why only 10:1 ?
Nate
Engine Machinist
FloydODB
Re: 536hp 347
Post by FloydODB » Sat Jun 15, 2013 10:23 pm
My bread and butter come from agriculture/industrial and service shops in the area. I do less than a dozen hot rod engines a year and very seldom fully assemble them complete with one or two getting dynoed. Being a small one man shop, I cant afford to push limits. 10:1,10.5:1,11:1 more power only shortens the fuse length,reduces reliability and that's not want my customer wanted.We are 36hp more than our goal and 60 more than what we would have been content with.
Daniel Brown
(269)930-1962
Bos's5.0
Re: 536hp 347
Post by Bos's5.0 » Sun Jun 16, 2013 11:08 am
What block?
FloydODB
Re: 536hp 347
Post by FloydODB » Mon Jun 17, 2013 11:18 pm
late 60's block. cant remember exactly. couldnt get a 2 piece to fit right so had it machined for a one piece. studded and girdled. stock pump made 63lbs @ 6800.
Daniel Brown
(269)930-1962
GARY C
Re: 536hp 347
Post by GARY C » Tue Jun 18, 2013 1:02 am
Good inspiration, I am building a 10.1 357 SBC very similar to this, I have my RHS heads just under 200cc's flowing 299 at .600 lift and looking at running a very aggressive solid roller in the 274 on seat range.
JohnsnsFord2@aol.com
Re: 536hp 347
Post by JohnsnsFord2@aol.com » Tue Jun 18, 2013 2:41 am
thats making alot of steam!! awesome job!!
Stephen Johnson #2162
Horace Johnson #2167
SS/D 427 Ford Fairlane NHRA-IHRA
Ex-Jim Van Cleve
1985 Mustang GT N/A 331
CamKing
Re: 536hp 347
Post by CamKing » Tue Jun 18, 2013 11:43 am
Glad it worked out.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Bos's5.0
Re: 536hp 347
Post by Bos's5.0 » Tue Jun 18, 2013 12:29 pm
Seems to be asking alot out of a factory 302 block of any kind. People have made more HP, but that was with supercharging and lower RPM's.
n5ifi
Re: 536hp 347
Post by n5ifi » Tue Jun 18, 2013 8:42 pm
FloydODB wrote:i need to thank everyone for their help and contributions.
Mike at jones cams
536hp @ 6800
475lbs @ 5300
Out of curiosity, what were the journal specs on your scat crank?
I've got one here that is 2.2490 across the board and 2.1235/6 on the rods.
Very little if any taper on either.
Nice Job by the way.
