GARY C wrote:Order a case of this and run what ever oil you want! Oil Extreme Concentrate additive.
http://www.oilextreme.com/enter.html
I have run several flat tappet cammed small and big blocks with this and Mobil 1 with no failures.
As anyone who has been following various oil discussions knows, there is no shortage of technically weak people chiming in, who have nothing to add to the discussion other than nasty negative comments. Of course they never provide any real world oil test data to put up against mine for direct “wear protection capability” comparison. They just repeat what they’ve always been told, and cannot get past the fact that actual test data brings into question how good high zinc levels really are. And don’t forget, my testing showed:
10W30 Joe Gibbs XP3 NASCAR Racing Oil synthetic = 95,543 psi, which puts it in the outstanding wear protection category, even with very low levels of zinc.
zinc = 743 ppm
phos = 802 ppm
Is there a zinc lover out there who is prepared to say that Joe Gibbs NASCAR oil is no good?
In any case, there are far more people who are technically sharp enough to understand the value of testing motor oil “dynamically under load” like I do, just like we test engines on the dyno under load. I get plenty of feedback in person, from emails and from PM’s from folks asking me to ignore the naysayers and keep posting motor oil test data that they cannot find anywhere else. So, I will. And if the nasty guys don’ like it, they can close out and go to another discussion. But, it will be their loss, because they will not be learning what the new testing tells us about motor oil.
So, to that end, I’ve order some David Vizard endorsed 5W30 Oil Extreme motor oil, and some Oil Extreme Concentrate additive. Vizard himself says that using high levels of zinc in motor oil is outdated technology, which is precisely what my testing has shown. Now even Vizard and I are consistent in our findings. These oil products use what he calls the new calcium sulfonate extreme pressure technology. Yet another example on not needing high levels of zinc.
I’m not affiliated with this product in any way. But, I thought it sounded interesting, so I’ll send the motor oil in for Lab Testing to see how much of what all is in it. And of course I’ll put it through my “dynamic wear testing under load” process to see how it shapes up against all the other oils. If it is as good as it appears, my testing will absolutely show it.
And for the concentrate, I will add the recommended amount to a modern low zinc oil that I’ve recently tested. Then I’ll send a sample of that into the Lab to see how the component levels have changed. And I’ll also I’ll put it through my “dynamic wear testing under load” process to see how it shapes up against all the other oils after having been modified. In the past, adding zinc additives have ruined the oils by reducing their wear protection capability. So, it will be very interesting to see if this new calcium sulfonate extreme pressure technology performs better.
Here’s a link:
For those who have no trouble understanding the value of this motor oil testing, and want to see how these products perform, stay tuned. In a month or two, I’ll post all the results.
540 RAT
