The flat areas between each pair of intake valves and exhaust valves are designed to squeeze air/fuel out from those areas and generate turbulence in that vicinity.ptuomov wrote:Is that BMW S1000RR piston designed to squish from the exhaust to intake side? Or what is going on there?
The piston dome approaches the head closely near the outer perimeter. Same intent as the above. But the reason for doing it at the piston rather than using a cloverleaf head is that doing it in the piston in these locations avoids shrouding charge motion on the sides of the chamber - most likely with the intent of enhancing whatever tumble they can get with such bore and stroke dimensions.
The piston dome is recessed into a bowl in the center because that's closer to where the spark plug is.
The whole intent is to get as much of the mixture as close to the spark plug as possible and generate small-scale turbulence in the outer reaches of the chamber so that the flame speed will be higher in the outer reaches once combustion gets going.
For what it's worth, my ZX10R has chambers somewhat similar to the BMW but the chamber is drawn in a little on each side (between the intake and exhaust valves) and the piston is flat in that area. The squish band is flat with the piston rather than being raised up following a raised piston dome the way the BMW does it.
edit: I found this better image of what the S1000R piston looks like ... actually, this is a Wiseco aftermarket piston, but same idea. The raised areas between the intake and exhaust valves, and the central dish, are readily visible.
