That was my opinion as well. However, I purchased a new LS7 exhaust rocker arm to examine it more carefully. There are witness marks on the reverse of the casting showing that the tip is pressed into a die of sorts thereby imparting a very even surface. Also, the surface is slightly convex from side to side which would generate a point contact.The Radius Kid wrote:I'm looking at the tip of that rocker arm and the factory finish looks horrible to me ... as cast,if my guess is correct.
There have been at least three variations of the LS7 exhaust rocker arm casting with the mass distribution slightly altered, presumably to help with the dissipation of dissonant energy into the parts of the valve train assembly.
With respect to the change in installed height my suggestion is to correct it to factory specs, at least with respect to the LS7 which I believe to be an example of a general class of problems (with respect to exhaust valve guide wear and subsequent valve head dropping) that are too complex to be adequately modeled.
