wyrmrider wrote:OK CNC
is this a weight limit class or does everyone have to find parts of unobtanium?
If he has a minimum weight he could do raised block, if not he can't- how much weight difference is there< would be hard to find that much elsewhere
I'd still think of the raised cam tunnel- btw do they allow gear drive?
can you get a headgasket for a large bore block and lay it over one of those spec heads?
can you match the bores/ new chambers to the heads?
would such a move allow more flow?
cheers
SHP pro-series is 174 lbs and not available in a raised cam. Dart little M is available raised cam but weighs 230 lbs. You can do a block lightening program on the little M to get it down to 165 or so but $$$$$.
Dirt cars are VERY front-weight sensitive, anything you can do to lighten the engine will pay more dividends than just horsepower. I'm talking about handeling and traction here which will have more effect on winning races than a few extra horsepower.
Even if you can't do much with the chambers, the large bore will pick up head flow with no other changes to the head. That's why it's important to know what size fixture a cylinder head was flowed on. Big difference from a 4.030 to a 4.125 to a 4.185
