digger wrote:what Al alloy are typically used?
In the patent, a key claim is that simply using a different aluminum alloy heretofore not used will result in a higher compressive yield strength and in this case will result in approximately a 25% increase over then-current state-of-the-art. The densities of the aluminum alloys are very similar to oneanother (as are the moduli of elasticity, as you point out).
... 2014-T6 aluminum alloy, which has a compressive yield strength of 58 ksi. More recently, 7075-T6 aluminum alloy has been used, which has a substantially higher compressive yield strength of 72 ksi.
... 7055-T77511, also referred to as HP007. This aluminum alloy has been available from Alcoa for some time, but never made into extruded bar stock for forging. By working with Alcoa, the inventors of the invention described herein obtained 7055-T77511 aluminum alloy from Aluminum Company of America “Alcoa” in extruded bar stock suitable for forging.
Under testing in drag racing engines generating in excess of 6,000 horsepower, the improved high performance aluminum connecting rod of the present invention has been found to have a compressive yield strength of 25 percent greater than 7075-T6.
... wherein said high performance aluminum connecting rod has a compressive yield strength of approximately 90 ksi.
