I am well aware of that. No offense to you intended. It is just a measure of my exasperation.Warp Speed wrote: First of all, the phrase you keep using "solution looking for a problem" wasn't mine.
Ok, that is kind of a generic catch-all which has been addressed in several instances already. So that cannot be the source of your complaint.Warp Speed wrote: Second, I already stated my views, and it is to free up oiling architecture in different combinations. Be it main oiling or accessory oiling such as piston oilers ect. Maybe it is driven by cost saving along with the oiling deal, as that would be a great place to save some material over a couple million pieces. As I said earlier, RWtech would probably know exactly why in the case of the LS engine.
Emissions and excess oil loading is my opinion. Additional oil loading from the centermain will put more stress on oil control rings in the center two bays. Mains two and four already evenly oil bay pairs 1-2 and 3-4 so the additional oil from the center makes the load on 2-3 disproportionate. Not only the groove is varied but also the aim and size of the slots on the thrust bearings and that is variance within the LS engine series.Warp Speed wrote: I'm still waiting to hear a clear explanation as to why the varying oil feed grooves in the main bearings?
This has also already been mentioned.
If you look at oil witness marks in the full length Corvette trapezoidal windage tray, chaotic flow over the third main is indicated. This means that the situation is even worse since chaotic flow could force most the oil from one bay pair to another versus evenly divided. I have had an explanation of the chaotic center flow in the LS up on my website for three or four years now and a suggestion on how to address it as well.
