piston damage question
Belgian1979
Post by Belgian1979 » Mon Mar 11, 2013 7:52 am
This is about a case I'm working on right now.
Below is a picture of a hemi dragrace engine piston. Can someone tell me what the scratced in the top land mean ? What could have caused this ?
Cubic_Cleveland
Re: piston damage question
Post by Cubic_Cleveland » Mon Mar 11, 2013 8:03 am
Possibly contamination, but most probably detonation + got hot and grabbed. Is that the intake valve side?
Any more pictures? Any other pistons have any damage?
FuelieNova
Post by FuelieNova » Mon Mar 11, 2013 8:10 am
I was curious about the other piston in the picture. It looks like theres a chunk out of it.
Tom
Belgian1979
Post by Belgian1979 » Mon Mar 11, 2013 8:28 am
Yes the other piston has a chunk out of the skirt. The engine fully disintegrated at the end of a dragrun. Alu rod broke and windowed the block.
This is a methanol engine. I'm wondering about wether or not it still needs cooling. It was setup as a top fuel car running on nitro (solid block, solid heads and such). Case was dismissed previously, but it turned up in court and we are discussing the cause. I concluded before that one of the contributing factors was detonation.
Engine was already disassemble and this was some time ago. Do not know anymore wether this was exhaust or intake side.
Cubic_Cleveland
Post by Cubic_Cleveland » Mon Mar 11, 2013 8:33 am
If it was running too hot I would think more of the piston would have grabbed, and more than 1 piston. Is this the only piston damaged apart from the one where the rod let go?
Belgian1979
Post by Belgian1979 » Mon Mar 11, 2013 8:57 am
This is one of the others. They all show some signs in the top ring land.
As said, engine was all apart when I saw it, which makes root cause analysis a problem.
twl
Post by twl » Mon Mar 11, 2013 9:00 am
I see this in old vintage hemi motorcycle piston failures.
It seems to be from piston rock.
We normally solve it with reduction in the diameter at the top ring land.
The top land gets a lot of heat and expands, and added to the rock, it gets scored. Sometimes it causes the top ring to get pinched.
Dave Koehler
Post by Dave Koehler » Mon Mar 11, 2013 10:04 am
X2 Just piston rock. IF it had not had an unscheduled dis-assembly you would still find that.
robert1
Post by robert1 » Mon Mar 11, 2013 10:45 am
Piston rock would just be polished wear above the ring. That is detonation from too lean, too much timing, not enough fuel flow, too much compression. This goes back I believe to your first visits here talking about aluminum wrist pins. By the time that you get to this level of HP the operator should know very well what they are doing. Just having enough money to buy this much HP is not very helpful. That would be the intake side and that is always the side that shows the first signs of detonation. Too bad something like this ends up in court as the builder has zero control over what the user might do to the engine. Experience is very expensive. I had a guy many years ago the burned the number 3 piston in a SBC alcohol motor 3 weeks in a row. I kept telling them it was too lean. After sending the carb back several times they finally got it right. I had to stay late each week to make sure they were able to race each week.
Dave Koehler
Post by Dave Koehler » Mon Mar 11, 2013 10:51 am
I should clarify piston rock. It happens. However the one shown is the "good" hole so take it with a grain of salt. The real issue is heat. The upper land area is smaller than the skirt for that reason and in some engines way smaller to combat the rock issue along with heat. Fatten her up a hair next time out?
Belgian1979
Post by Belgian1979 » Mon Mar 11, 2013 12:03 pm
robert1 wrote:Piston rock would just be polished wear above the ring. That is detonation from too lean, too much timing, not enough fuel flow, too much compression. This goes back I believe to your first visits here talking about aluminum wrist pins. By the time that you get to this level of HP the operator should know very well what they are doing. Just having enough money to buy this much HP is not very helpful. That would be the intake side and that is always the side that shows the first signs of detonation. Too bad something like this ends up in court as the builder has zero control over what the user might do to the engine. Experience is very expensive. I had a guy many years ago the burned the number 3 piston in a SBC alcohol motor 3 weeks in a row. I kept telling them it was too lean. After sending the carb back several times they finally got it right. I had to stay late each week to make sure they were able to race each week.
Your correct. This is the engine in one of my first threads which in the mean time turned up in a litigation.
I second your opinion. It's a bullshit case that should not end up in court. If you race, you will blow up an engine sooner or later, especially in a dragrace engine of this type.
I have seen other detonation issues as well among which a crack in the ring land, the hammered piston pin bore.
It also had oiling issues.
As stated this is an engine with an experimentational wrist pin (steel outer shell with an alum inner).
What still bothers me are the buttons on the skirts. I can only imagine the amount of clearance it needs to run to get them in. It will provide the opportunity for the piston to cock in the bore imo.
There is something else as well : when I saw the engine they presented me with a virgin piston and some pins. As I know now by experience, if well oiled up and with suitable clearances, the pin should slide through the pin bore without effort. The pins in question did not, meaning they were too tight as well.
It desintegrated at the end of the strip, meaning it stayed together pretty well, all else taking into consideration.
I think this team went up into a class with to little experience.
Belgian1979
Post by Belgian1979 » Mon Mar 11, 2013 12:06 pm
Dave Koehler wrote:I should clarify piston rock. It happens. However the one shown is the "good" hole so take it with a grain of salt. The real issue is heat. The upper land area is smaller than the skirt for that reason and in some engines way smaller to combat the rock issue along with heat. Fatten her up a hair next time out?
Dave this is not my engine.
It's a case I have to handle. A case that should not have made it into court.
robert1
Post by robert1 » Mon Mar 11, 2013 12:32 pm
I don't see any signs of aluminum wrist pins. The buttons have been used forever in all forms of racng, Top Fuel, Funny Car, boats, any high horse power application.
keithdyer
Post by keithdyer » Mon Mar 11, 2013 3:20 pm
Looks like the guy who bumped the mag or put the main jet in should be the one on trial . . . . .
Strange Magic
Post by Strange Magic » Mon Mar 11, 2013 6:37 pm
Going to venture to say that this issue might have been caused by wrist pins sticking from either inproper clearance or expansion of that wrist pin for some reason. I would venture to say that it stuck in a certain position and tore at the top of the piston. The rod that exploded might have galled the pin and stuck it so bad that it locked/siezed it onto the small end shattering the rod.
This would seriously concern me. Why would someone do such a thing?
strangemagicperformance.com
