Hi Wishicouldbe,wishicouldbe wrote:360, bored 60, forged flat top pistons, stock crank and rods, plasma moly top rings, edelbrock heads, comp cams BMT, rpm air gap...
Freshly built engine with about 100 miles, has lots of blow by, smoke out the exhaust when you give it part or full throttle but not at idle.. Is it the rings not seating or something else possibly.. If its the rings how can I get them to seat where it with quit smoking
How did you clean the cylinders for assembly?
How is the power?
So there is blowby (out a breather?) AND smokey exhaust?
Could you describe the look and smell of the exhaust smoke?
Dual exhaust? Do both banks smoke ? (The rpm air gap has no exhaust crossover port, right?)
Have you looked at the individual ex ports as suggested by others?
Dan T
