I am sure your number when it shows up at Dart they laugh at you when you called them and told them they could not machine lifter bores. If you forgot about that post I can find it for you.gmrocket wrote:they didnt seem concerned because they have call displayCNC BLOCKS wrote:Belgian1979 wrote:If it was stretched to much, it show up as a change in diameter presumably in the area where it broke.
If not, watch for circles on the surface of the break line and look for lines and were they originate from.
Anyway I can understand Carl's concerns with this.
Did you contact ARP ?
I did contact ARP and they did not seemed to concerned, They told me they sell 100s's of thousands of bolt and they do get calls once in a while that one has failed.
As long as its not a common problem I am fine with that.
I figured if there was a problem there would be other engine builders here seeing the same results.
Here is you post
CNC BLOCKS wrote:gmrocket wrote:
ahhh, now all of a sudden some Dart blocks you have are .8436" what will they measure on monday? just let me know so i know which day to get a block from you
you have a very short memory there Carl. it was you who was whinning over in the hydro roller lifter thread about the Darts being .844" remember? then i said not according to Darts spec's, they are suppose to come .8427" to .8437", and Dart specifically notes that they will be on the small side to accomidate the difference in lifter o.d. specs and could need to be touched with a hone to get the required clearance....maybe you can post that link over here from Darts site
then out of the blue i get an email from Dart saying i can have the lifter bores to my spec..so to be 100% sure i said i have a .8415" lifter and i want .0015 clearance and require a .843" bore...they said no problem....thats what the email says.
i hate repeating myself but it seems like i have to with you. it looks like you have a problem talking to Dart because what they told me is totally different. maybe this will clear up what you and Dart dont seem to agree on,,,but why am i the middle man? if they actually are .844", then Dart should correct that and ship them to what there posted spec's are
ya, and nobody is using .842" lifters anymore...your funny.
Once again I see alot more lifter bores then you do ALLLLLLL the SHP blocks I see are to blue print size .8438 to 8443 the Little-M and Big-M I have here are right at .8436 which it to Darts spec Like I said all the Little-M, Big-M and Iron Eagle blocks I machine I have machine the lifter bores to either .875 or .904 At least 60% of the SHP blocks I see go to .904 also I machine alot of cam tunnels for either over size babbit or roller cam bearings. Are you set up to do that ???
It looks like you contacted Dart and Dart did not contact you, It looks l ike you went cring to them. Also your not even Dart dealer or don't even have equipment to do lifter bore work and your arguing to a guy that blue prints block for a living and how far did this get you????gmrocket wrote dont forget, they contacted me and told me no problem...ok, its on the way maybe Dart doesnt want to talk to you
Also you may want to cry to World Products and GM because there lifter bores are to blue print size and you .841 lifers are not going to work let me know how far you get with them
