Page 1 of 1
Sm Blk Chevy Ring Set Number
Posted: Fri Feb 15, 2013 6:38 pm
by ProPower engines
Hey guys
I am havng trouble finding a ring set for some 238 +30 pistons.
They are a 1/16 1/16 1/8 and I am looking for a set with a standard tention oil ring.
The only rings set numbers I am coming up with have a low tention oil ring.
If anyone has a calaloge that lists such a ring and would not mind posting whats available that would be great :D
I was going to get a set from Total seal but the cost is retarded compared to a conventional ring set.
Thanks again
Dave
Re: Sm Blk Chevy Ring Set Number
Posted: Fri Feb 15, 2013 7:29 pm
by wyrmrider
two steps forward one step back :)
Speed Pro catalog shows
R-9755 chrome
R-9211 file fit
R-9967 standard gap
Hastings cross references 2M5522
for all
Posted: Fri Feb 15, 2013 8:01 pm
by GOSFAST
The number above, for "moly's", the R9967's are correct, std. gaps and S/T, the R9211's are F/F, L/T.
You also have R10315's, F/F, S/T.
Thanks, Gary in N.Y.
P.S. The only issue I forsee with the latter number is going to the available oversizes, they may be tough to find in +035"?? Can find out Monday if necessary.
Posted: Fri Feb 15, 2013 8:35 pm
by ProPower engines
wyrmrider wrote:two steps forward one step back :)
R-9755 chrome
R-9211 file fit
R-9967 standard gap
for all
the speedpro ring is out of stock to the factory and no word on the hastings number till monday
Thanks for the help guys
Posted: Fri Feb 15, 2013 8:37 pm
by ProPower engines
GOSFAST wrote:The number above, for "moly's", the R9967's are correct, std. gaps and S/T, the R9211's are F/F, L/T.
Thanks Gary
You are right no .035's I tried almost everywhere to find some
Posted: Fri Feb 15, 2013 11:42 pm
by wyrmrider
the Hastings are standard tension
269-945-2491
Mahle/ clevite NG
Grant 55001
Posted: Sat Feb 16, 2013 2:04 am
by user-3597028
I can't believe a CR series Total Seal set is more that $75. I've always found them to be cheaper than Sealed power or Perfect Circle.
Posted: Sat Feb 16, 2013 2:29 am
by Wolfplace
Cedarmachine wrote:I can't believe a CR series Total Seal set is more that $75. I've always found them to be cheaper than Sealed power or Perfect Circle.
That kind of depends on if you are a WD or not
Jobber is about $100 & Pro Jobber is about $113
Dave
If you still need them PM me & I will get them at cost for you but shipping on one set to you is probably going to suck,,,,
Posted: Sat Feb 16, 2013 5:01 am
by ProPower engines
Thanks Mike
I was going to call hastings back on monday but not sure what the cost will be,.
I will call you monday or if you want to PM me a cost I may just get them from you and save the extra call
Thanks again
Dave
Posted: Sat Feb 16, 2013 12:53 pm
by Wolfplace
ProPower engines wrote:Thanks Mike
Thanks again
Dave
PM sent :)
Posted: Sat Feb 16, 2013 3:17 pm
by ProPower engines
Thanks again
Dave
PM sent :)
Recieved
Thanks Mike
Posted: Sat Feb 16, 2013 5:52 pm
by ProPower engines
Thanks guys
Got er handled :D
