Sm Blk Chevy Ring Set Number
ProPower engines
Post by ProPower engines » Fri Feb 15, 2013 6:38 pm
Hey guys
I am havng trouble finding a ring set for some 238 +30 pistons.
They are a 1/16 1/16 1/8 and I am looking for a set with a standard tention oil ring.
The only rings set numbers I am coming up with have a low tention oil ring.
If anyone has a calaloge that lists such a ring and would not mind posting whats available that would be great :D
I was going to get a set from Total seal but the cost is retarded compared to a conventional ring set.
Thanks again
Dave
wyrmrider
Re: Sm Blk Chevy Ring Set Number
Post by wyrmrider » Fri Feb 15, 2013 7:29 pm
two steps forward one step back :)
Speed Pro catalog shows
R-9755 chrome
R-9211 file fit
R-9967 standard gap
Hastings cross references 2M5522
for all
GOSFAST
Post by GOSFAST » Fri Feb 15, 2013 8:01 pm
The number above, for "moly's", the R9967's are correct, std. gaps and S/T, the R9211's are F/F, L/T.
You also have R10315's, F/F, S/T.
Thanks, Gary in N.Y.
P.S. The only issue I forsee with the latter number is going to the available oversizes, they may be tough to find in +035"?? Can find out Monday if necessary.
Jan. 2016 - New York Street Ride 7.56 @ 190 @ 3800#
(https://www.google.com/url?sa=t&rct=...12064104,d.cWw)
ProPower engines
Post by ProPower engines » Fri Feb 15, 2013 8:35 pm
wyrmrider wrote:two steps forward one step back :)
R-9755 chrome
R-9211 file fit
R-9967 standard gap
for all
the speedpro ring is out of stock to the factory and no word on the hastings number till monday
Thanks for the help guys
ProPower engines
Post by ProPower engines » Fri Feb 15, 2013 8:37 pm
GOSFAST wrote:The number above, for "moly's", the R9967's are correct, std. gaps and S/T, the R9211's are F/F, L/T.
Thanks Gary
You are right no .035's I tried almost everywhere to find some
wyrmrider
Post by wyrmrider » Fri Feb 15, 2013 11:42 pm
the Hastings are standard tension
269-945-2491
Mahle/ clevite NG
Grant 55001
user-3597028
Post by user-3597028 » Sat Feb 16, 2013 2:04 am
I can't believe a CR series Total Seal set is more that $75. I've always found them to be cheaper than Sealed power or Perfect Circle.
Wolfplace
Post by Wolfplace » Sat Feb 16, 2013 2:29 am
Cedarmachine wrote:I can't believe a CR series Total Seal set is more that $75. I've always found them to be cheaper than Sealed power or Perfect Circle.
That kind of depends on if you are a WD or not
Jobber is about $100 & Pro Jobber is about $113
Dave
If you still need them PM me & I will get them at cost for you but shipping on one set to you is probably going to suck,,,,
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
ProPower engines
Post by ProPower engines » Sat Feb 16, 2013 5:01 am
Thanks Mike
I was going to call hastings back on monday but not sure what the cost will be,.
I will call you monday or if you want to PM me a cost I may just get them from you and save the extra call
Thanks again
Dave
Wolfplace
Post by Wolfplace » Sat Feb 16, 2013 12:53 pm
ProPower engines wrote:Thanks Mike
Thanks again
Dave
PM sent :)
Mike
A tour of my shop
The Dyno
John Wayne
ProPower engines
Post by ProPower engines » Sat Feb 16, 2013 3:17 pm
Thanks again
Dave
PM sent :)
Recieved
Thanks Mike
ProPower engines
Post by ProPower engines » Sat Feb 16, 2013 5:52 pm
Thanks guys
Got er handled :D
