How significant is the power gain switching to Roller Cam bearings, and in testing were any significant power gains made by switching from the typical SBC core to a 50mm or 55mm core?
Thanks.
Roller Cam Bearings/50mm cores
Don,
If you don't mind, I'd like to get a little more into this?
With a wetsump engine that may never see more than 7,000rpm on the street, how much would you reduce the oil pressure? Utilizing the roller cam bearing of course.
And this may sound crazy but what exactly do you mean by "different cam lobes"?
Sorry for all the questions, just trying to learn.
Thanks,
Chuck
Thanks,
Chuck
I was really speaking pump capacity - thinner/shorter pump gears. Check out this http://www.popularhotrodding.com/engine ... c_28_z.jpg
The cam lobes? Lobes designed with a larger basecircle.
In Memory of Don Terrill
SpeedTalk Owner/Admin
