That knock sensor was fitted to a number of vehicles: Buick, Cadillac, Chevy, Olds and Pontiac.Belgian1979 wrote:Standard motor product KS2, which should be equivalent to a 1986 knock sensor on iron gen I block.
I've found a formula to calculate the frequency based on the bore size. It pointed out 2.730 kHz.
All engines were 4.3 to 5.0 liters in displacement.
The KS2 sensor output range is 5.5-6.4kHz, which is very close to my calculation of fundamental knock frequency based on bore diameter. Your formula might have a problem since it is way off the mark.
All engines have three knock frequencies, depending on which axis is being considered. The highest is often more than triple that of the lowest.
