604 crate 4bl or 360ci 2brl? please help me decide
punkracer
Post by punkracer » Tue Jan 01, 2013 11:33 pm
Dirt latemodel, motor option legal 604 with 4 barrel carb 2350#. Or no touch 4412, 360ci no port bowtie head,flat tappet cam .874 lifter 11.1 max comp.wet sump.part #2701 or 5001 eldelbrock intake. #2400. No rpm limits on either. Must use sunoco 110 track fuel on both options. Most guys run the 2brl motor with very light rotating stuff and turn them 8000+ rpm. I rather do a 604 cuz there simple and marketable. What do you guys think? Thanks to all who read
CamKing
Re: 604 crate 4bl or 360ci 2brl? please help me decide
Post by CamKing » Wed Jan 02, 2013 11:18 am
It all depends on your definition of "legal 604" :wink:
The 2bbl will beat an out of the box 604.
A 604 that's been built to make as much power as possible, and still pass tech will beat the 2bbl.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
23Root
Post by 23Root » Wed Jan 02, 2013 12:15 pm
are they making you run a chip on the 604? thats what they do here and it limits rpm to around 6800 so the 360 will kill the 604.
CNC BLOCKS
Post by CNC BLOCKS » Wed Jan 02, 2013 1:37 pm
punkracer wrote:Dirt latemodel, motor option legal 604 with 4 barrel carb 2350#. Or no touch 4412, 360ci no port bowtie head,flat tappet cam .874 lifter 11.1 max comp.wet sump.part #2701 or 5001 eldelbrock intake. #2400. No rpm limits on either. Must use sunoco 110 track fuel on both options. Most guys run the 2brl motor with very light rotating stuff and turn them 8000+ rpm. I rather do a 604 cuz there simple and marketable. What do you guys think? Thanks to all who read
If your going to turn a 2 barrel 8000 I would go with a 6.250 rods as those builds don't fall of as fast as the 5.7 roded engines.
Website is up and running
Machine shop tour
Monthly Specials
punkracer
Post by punkracer » Thu Jan 03, 2013 2:24 am
our teck is pretty lax. they will pump and whistle the 604 and look for a gm bolt. check fuel but thats about it. anybody know where i can get a 604 thta will pass these rules? and yes, money is an object
Robbie DeVane
Post by Robbie DeVane » Thu Jan 03, 2013 5:14 pm
Call (R.E.D.) Race Engine Design talk to Ronnie. He builds some of the fastest create motor's in the country and the price isn't that bad. Tell him that I told you to call. I don't know where you are located but he is in N.-GA. around the Tenn. Ga. border.
http://www.devanecarbs.com
DeVane carburetors are precision assembled and calibrated to YOUR combo. Are you ready for the next level of performance?
punkracer
Post by punkracer » Fri Jan 04, 2013 11:49 pm
ok, just found out i can use e-85 on the crate only. will that be a boost over the 110 sunoco? what about chp type fuel? i should beable to get my hands on pure ethanol and mix it e-85 with a race gas. any ideas if im getting closer to the 2 barrel motor if i go that route?
rp87stang
Post by rp87stang » Sat Jan 12, 2013 8:42 pm
When you say legal crate 604, is that one with Nesmith or Fast track seals
