Alas, something about which we can now nod in rueful agreement. Closer inspection (it didn't hardly take a microscope.. ) of the block mentioned above reveals that the collective wisdom of S/T was right again.DaveMcLain wrote:... the real problem with any of the production Ford small block engines is that the blocks just don't have much main webbing.
It's also clear that as per Walter M.'s comment, bigger studs can make things worse. I'm sure the (#2) web would have failed even sooner with the reduced cross section resulting from 1/2" studs. It's hard to see the full extent, but the crack crosses from the broken cap down the web, across towards the opposite bank and also down to the cam bore.
Looks like we'll be brown-bagging it for lunch for a while to finance the Dart piece. Anyone have observations re their SHP Vs Iron Eagle and various mfgrs. aluminum offerings?
