ARP bolt sanity check
RAS
Re: ARP bolt sanity check
Post by RAS »
Extreme Pressure Lube can be ordered from Chicago Manufacturing & Distribution Co. in Gagetown Mich. call 1-800-537-2956. Works really well as an assembly lube also.
Strange Magic
Post by Strange Magic »
Has anyone ever lost a rod bolt, or had the opportunity to find one loose because they didn't use the stretch method and only used the torque method?
I'll tell you, that in 30 years i've never had a rod bolt come loose and I do not use the stretch method. When my engines go to final assembly, the rod bolts have been torqed and undone about three times. I am very concerend about the stretch method compromising the rod threads and the bolt it self. This is just my opnion, I feel it does more harm than good.
strangemagicperformance.com
axegrinder
Post by axegrinder »
apprentice, did you lube the underside of the bolt head every time? That gaulling would make me want to replace the bolt and spot face the cap and start over.
Denis
Trump might screw us
HILLARY WILL SCREW US
