Very much know that Hence I worded it v8 NA. I doubt they would have put it in (the v6 I mean) otherwise. However, thats a 1/2 tonne engine, and no more. Since the gen V is not going into trucks until what, 2014? Fords v8 engine might beat them to the punch DI wise, I recall reading that there were locations for the injectors in they cylinder heads but ATM not utilized. So ford is holding back for reasons unknown. My point being I'm interested in what the comp and displacement specs will be for the 3/4 - 1 tonne gas engines rated for some real work with DI. I'm impressed with how much di + vvt can widen the powerband on gm's 4cyl, towards the bottom, easily taking the job of previous v6's. Looking forward to see this tech in a v8. With some low gearing, some aero improvements, Mid 30's might be possible for the next gen trucks.Lem Evans wrote:The V6 Ford engine very much does have D.I. in the F150.Rizzle wrote:Its nice to see some info about the next Gen v8 from GM. I'm waiting to see how the truck engines do in terms of displacement and compression. These would be the first na direct injection truck engines, correct? Unless ford has added it for their v8, they had the feature in mind with the scorpion? engine if i recall correctly.
I'm sure the ecm protocol will get cracked, just a matter of time with the right people involved.
Currently a major fan of all this tech we are seeing to keep power levels high, while lowering fuel consumption. Seems like with a lot of things, we've found a nice spot in terms of performance and now to quest to lower fuel/power/space consumption is taking over.
Yeroon
Edit: maybe the v8 wasn't so clear (ie missing ), my bad.
