Weslake (Kugelfischer?) IR injection trumpets 70's Ford RS
Caprimaniac
Post by Caprimaniac » Sun Oct 21, 2012 5:04 am
One of my old friends bought a set of trumpets w/ throttle plates (IR throttlebodies) for his 2.6V6 Kugelfischer injected Ford Capri RS.
Our guess is that Weslake made these trumpets. They were available as a Ford RS part back in the day.
There are 6 trumpets with individual throttle plates and they need to be replaced. My pal have looked at Weber throttle plates but got confused by the different angles available on the plates.
The bore is 40mm, so plates from 40mm Weber might fit. (Jeez- I don't know if he's checked the bolt pattern on blade to shaft bolts!....)
As there are air bypass holes in some of, but not all(!?), trumpets, the blade need to cover those, at least.
Anyway. Anyone on ST have any knowledge on which blades should (could) be used in these trumpets?
Regards
RS
Caprimaniac
Re: Weslake (Kugelfischer?) IR injection trumpets 70's Ford
Post by Caprimaniac » Sun Oct 21, 2012 12:16 pm
dfree383
Post by dfree383 » Mon Oct 22, 2012 3:54 am
I'm sure some one like BLP could make them for you if you can't find replacement ones on the shelf somewhere.
SMITHBERGRACING
Post by SMITHBERGRACING » Mon Oct 22, 2012 5:01 am
I'm sure the guys over at Hilborn could take care of that. Give them a ring.
949-360-0909
Unkl Ian
Post by Unkl Ian » Mon Oct 22, 2012 12:06 pm
Kinsler.
Caprimaniac
Post by Caprimaniac » Tue Oct 23, 2012 6:49 am
Thanks. I'll call Hilborn, Kinsler and BLP for help unless i can resolve the angles and find something that fit....
Regards
RS
