automotive breath wrote:Here's a picture of the Brodix heads I mentioned. With tall domes I put the groove between the valves to assure the squish flow makes the trip over the dome. I thought about adding feeder grooves into the main groove but decided not to mutilate Lobe's prize possession.
Have you noticed differences between deeper chambers vs shallow chambers?...how about "convex" design vs "non convex"?
I'd love to know how this would work out with a turboed setup.
The exhaust temps are lower but the pressure differential should theoretically be higher considering the 'more complete' burn and detonation is occuring a lot later than normal...there's got to be some fun to be had there somewhere
stevek wrote:I'd love to know how this would work out with a turboed setup....
I ported and grooved a set of LSx heads for a twin turbo 10.5 heads up car a few months back. They were for a 6.0L Iron block in a Nova body. I haven’t heard from the owner lately, I'll give him a call and try to get some details.
Windsor377 wrote:Interesting. What kind of piston to head distance do you run on the squish area? Do you mind mentioning the cylinder head type and amount of boost?
0.0374" in the little squish area that is there...the pistons are dished,just like the ones Automotive Breath had a photo of. It's just a 0.3 or so wide squish band. Heads are 4-valve Mitsubishi 3000 GT (looks identical to a Ford 4.6 (?) I think...saw a photo of that head once and it has the same OHC roller-rocker layout and shape of the chamber and all)...only difference was that it had 4 chambers VS. the Mitsu's 3,it being a V6. It's a GT42R single turbo'ed car. We ran about 34 psi on pump last week,AFR's still a bit rich and the EGT's are so low it's silly....
-Bjørn
"Impossible? Nah...just needs more development time"
Cool. Thanks. Do you mind posting some dyno info if you get a chance to dyno it?
Sure,as long as the owner of the car agrees to me posting it. I guess we'll slam a few DynaPack units on it and get the AFR's right and find out where the detonation threshold now lurks...it was audible at just under 32 psi before.
-Bjørn
Well, I don't want you to compromise anything. If you can, I'll appreciate it, if not, I'll understand.
I'm in the early stages of as blown R/S - UDR combination and this just might be very helpful.
i've been watching and reading this thread for months now.
maybe 20 years ago i saw a set of max wedge dodge heads that had groves in them,5 groves,in a sun burst pattern.these heads were at a local race shop and i have no history on them. the groves were wider than what i see you guys doing,and maybe not as deep.
randy
Here’s some pictures from Bart Jr.s Nova, he made a final round appearance at the 2006 Sports Nationals at No Problem Raceway. Piston and head pictures are after plenty of run time. The incredible part of this story is the car is no E!
