Bigger oil gallery
Bigger oil gallery
Anyone seeing any issues with machining the main oil gallery of a block bigger? I have an engine with some oiling problems to a specific rod and it's basically an oil volume problem,not pressure...so I'm thinking about increasing the volume available in the main gallery (it's just over 3/8" dia at the narrowest point,in the middle of the gallery) and probably port the junctions to increase volume flow. Issues?
-Bjørn
"Impossible? Nah...just needs more development time"
Porsche 944 Turbo... there's a pic at my "oil pump cavitation"-thread now. viewtopic.php?t=3170 ... Not much room to make anything bigger there...tweaks wrote:What motor are you working on...suggest you look at machining out pump body / housing and fitting larger gears in pump to increase capacity of oil as well as opening up that critical area..
-Bjørn
