Most HP w/small cam?
Postby paul s. » Fri Aug 17, 2012 7:29 pm
What is the most N/A horsepower you have made with (what you would call) a small cam? And what was the application? Doesn't matter if it is flat tappet hydraulic or solid roller. If I recall, Joe Sherman made over 600hp from a 360ci sbc with a 230@.050 HR Isky and some ported AFR's in the 1st Engine Masters.
http://www.sandovalperformance.com
custom built Pontiac 400's and strokers
paul s.
Re: Most HP w/small cam?
Postby bigjoe1 » Fri Aug 17, 2012 9:09 pm
I can do that one better yet== Comp Cams made me a special grind ( still 230 at 050 ) after I won with the Isky cam, and it made 630 HP at 6500 in that same engine, I was soo impressed, I started using Comp Cams in everything I build now- This was back in jan of 2003. I am still impressed.
JOE SHERMAN RAQCING
bigjoe1
Show Guest
Show Guest
Postby cuisinartvette » Fri Aug 17, 2012 9:43 pm
I have got to know how did you do that Joe numbers like that could almost sway me away from a a solid. lol.
Know you cant tell all but you had pre prod. 195s? Can you say what kind of intake/comp/carb by chance? Thats a lot of power for what it is nice.
Running plenty more head/cam and doubt Im making anywhere near that.
cuisinartvette
Postby randy331 » Fri Aug 17, 2012 10:36 pm
When I have posted enough to be a guru, instead of an expert, will I know it all???
randy331
Postby bigjoe1 » Fri Aug 17, 2012 10:54 pm
The Comp Cams grind I used was a TK solid roller profile with Speed Pro stock hyd roller lifters. The heads were the AFR raised runner sprint car type heads that I ported myself to keep the runners as small as possible. just for kicks, I put that engine in my kids 65 Nova, and it run 10.40 at 128 with totally the wrong rear end gears and converter. It probably could have gone much faster- I ran a 1025 CFM carb that was really big for that small engine too. Headman made me some headers with lazer cut port matched flanges that fit the heads perfectly, and stamped the stock part numbers on them . I did what I had to do to win.
JOE SHERMAN RACING
bigjoe1
Show Guest
Show Guest
Postby cuisinartvette » Sat Aug 18, 2012 12:15 am
Need another kid to spin wrenches for ya? :D
I do eat a lot.
cuisinartvette
Postby Joel Dubose » Sat Aug 18, 2012 12:08 pm
We commonly build street engines, that use pump fuel that make 1200 hp +
JDE Heads & Manifolds
I'm WD with AFR,Edelbrock and many other parts and castings suppliers.
JDE has port programs In popular castings for performance uses, If you would like a port designed for your project contact me 704-658-6951
Joel Dubose
Postby rfl28 » Sun Aug 19, 2012 10:20 am
Joel Dubose wrote:We commonly build street engines, that use pump fuel that make 1200 hp +
NA? What combination?
stand on it!
rfl28
Postby Joel Dubose » Sun Aug 19, 2012 10:55 am
Great big ci engines, up to 1005 ci. Na with Fi.
Joel Dubose
Postby firebuick » Tue Aug 21, 2012 7:47 pm
bigjoe1 wrote:I can do that one better yet== Comp Cams made me a special grind ( still 230 at 050 ) after I won with the Isky cam, and it made 630 HP at 6500 in that same engine, I was soo impressed, I started using Comp Cams in everything I build now- This was back in jan of 2003. I am still impressed.
JOE SHERMAN RAQCING
wow that good those head must flow a lot of air
buick regal 1983 355 chevrolet turbo 350 4.10 gear gn rear eddy rpm heads comp cam 274s bowtie intake 750 double pumper
firebuick
Postby PackardV8 » Tue Aug 21, 2012 8:25 pm
Random thoughts:
1. Today's good heads and intakes don't need the duration common in the bad old days of OEM double hump iron heads.
2. Today's small high intensity cams are way bigger in total area under the curve than the longer duration common in the bad old days.
3. Today's springs, light valves, light retainers follow the high intensity lobes better than the heavy stuff did in the day.
Bottom line - small today is way different than small back then.
jack vines
PackardV8
Postby loudandproud » Tue Aug 21, 2012 8:27 pm
Pics or it didnt happen~~!!!
Just kidding... but no really i wanna see pics...
"Buying parts I dont need, with money that I dont have, to impress people that I dont know".
loudandproud
Postby bigjoe1 » Tue Aug 21, 2012 8:29 pm
Very interesting Jack.. I still think thr duration is very important, especially if you need to turn some high RPM.
JOE SHERMAN RACING
bigjoe1
Show Guest
Show Guest
Postby PackardV8 » Tue Aug 21, 2012 9:35 pm
Hi, Joe,
Agree, Joe, but that's a different discussion. He was asking about "Most HP w/small cam". To do that, we have to define small. And small depends upon displacement. You've pretty much done that and I'd agree, 230@.050" in a 350" with an EMC 6,500 RPM limit is the end of small. Above that lies more serious work for real race engines and unlimited RPM.
However, 350" is ant shit in some circles. If you ain't got more than 500", you can't bench race in some garages. At that displacement level, 230@.050" is way, way too small.
And we haven't even discussed lift. Back in the day, .300" lobe lift was getting serious. Today, .500" lobe lift on some engine families won't get you bragging rights.
Bottom line - the OPs question is one asked just for making conversation after the first beer.
jack vines
PackardV8
Postby Joel Dubose » Wed Aug 22, 2012 7:33 am
That's no problem, goto Sonny's racing engines website and look all you want. We just did on for an Australian and Sonny brought back one of their hotrod magazines from their country , it was right on the cover, it was titled because I can... Lol
Joel Dubose
Next
Return to Engine Tech
Who is online
Users browsing this forum: 1NRO, Bing [Bot], mod73, redliner, sixty8 and 11 guests
