What stroke to use for my new SBC combo?
Postby FastBuick » Fri Aug 17, 2012 12:44 pm
Hello everyone,
I had to buy a new block, so I am possibly looking at changing my engine combo also. I just bought a Dart Iron Eagle block with a .434" raised cam, .905" lifter bores, spread pan rails, a 60mm babbitt cam journal, 9.025" deck, and will most likely be a 4.165" bore to start.
Right now I have a 3.625" stroke crank, 6.00" rods, and a set of CFE 268cc intake runner 18 degree heads with 2.200" intake and 1.600" exhaust titanium valves. I will also be using an Edelbrock Victor Glidden Spyder Intake manifold that has been ported, and a Pro Systems 1100 Dominator.
It is a 3100# car with a 7000 stall converter, and a TH400 with all lightweight internals and a 2.10/1.40/1.00 gear set.
My 398 combo ran a best of 9.25 @145 with a powerglide in it, turning 9000 RPM. The TH400 is new and hasn't been used yet.
My question is what bore stroke combination would work best with the heads, car, and drivetrain I have? I'm looking for the most gains and I am not afraid to turn RPM. So far my idea was a 3.750" stroke, but was looking for more info before I make the decision. Or should I keep the stroke the same?
Any help is greatly appreciated.
Thanks
John
FastBuick
Re: What stroke to use for my new SBC combo?
Postby jason snyder » Fri Aug 17, 2012 9:32 pm
I would PERSONALLY go 3.875 stroke , and sell the converter for something that will fit your new LOWER powerband ...Its a WIN win SITUATION !and you will make alot more power everywhere !
jason snyder
Postby CNC BLOCKS » Sat Aug 18, 2012 6:52 am
With a 9 inch deck i would go with a 3.875 with a 6 inch rod, better rod ratiio over the 4 inch stroke.
With the 60MM cam tunnel did you get the DRCE-3 oiling option?
http://WWW.CNCBLOCKSNE.COM
IS A DIVISION OF
HINKSON AUTOMOTIVE
RESEARCH & DEVELOPMENT
We are WD on AFR, Dart, Wiseco, JE, CP, Crower, Manley, CARRILLO, Callies, King's Crankshaft. COMP CAMS, Diamond pistons ETC.
CARL HINKSON 207-892-7215
CNC BLOCKS
Postby FastBuick » Sat Aug 18, 2012 10:26 am
jason snyder wrote:I would PERSONALLY go 3.875 stroke , and sell the converter for something that will fit your new LOWER powerband ...Its a WIN win SITUATION !and you will make alot more power everywhere !
Do you think I will still gain more horsepower using the same heads? Or will I just shift the RPM range to lower RPMs?
FastBuick
Postby FastBuick » Sat Aug 18, 2012 10:29 am
CNC BLOCKS wrote:With a 9 inch deck i would go with a 3.875 with a 6 inch rod, better rod ratiio over the 4 inch stroke.
Yes all that was done at Dart. The oiling, cam tunnel, lifter bores with special bushings, and the .434" raised cam were all options that I ordered.
And as far as rod ratio, has the optimum rod ratio changed over the years? It used to be 1.7-1.8 was optimum. Recently I've heard Pro Stock was using 1.5-1.6. Is rod ratio still a concern or doesn't it really matter much? That's one of the reasons I was concerned about changing the stroke. The rod ratio and bore/stroke ratio are still good with the 3.625 stroke but obviously get worse with more stroke. What effects will this have? I'm thinking cylinder wear is one.
FastBuick
Postby CNC BLOCKS » Sat Aug 18, 2012 10:48 am
Do search on rod ratio see what you come up with.
IS A DIVISION OF
HINKSON AUTOMOTIVE
CNC BLOCKS
Postby FastBuick » Sat Aug 18, 2012 11:00 am
Ok no problem. I was just hoping to get some real world recent theories instead of ones in a book or online that may be 10 years old and outdated.
FastBuick
Postby 62ChevyII » Sat Aug 18, 2012 11:09 am
FastBuick wrote:Ok no problem. I was just hoping to get some real world recent theories instead of ones in a book or online that may be 10 years old and outdated.
I think he meant search here on Speedtalk for rod ratio, I think it has been a hot topic in the not too distant past.
62ChevyII
Postby FastBuick » Sat Aug 18, 2012 11:18 am
Ok will do. I guess I took that wrong. That happens with text lol.
I guess my main question is will there be significant gains with more stroke and the heads I have? I just don't want to waste money. Looking for good bang for the buck so I can utilize my money wisely and use it in another area if there's a better option.
FastBuick
Postby rookie » Sat Aug 18, 2012 11:27 am
Here is a good thread in the advanced section that has side load calculations. viewtopic.php?f=15&t=32153
Has Anything You've Done Made Your Life Better?
rookie
Postby levisnteeshirt » Sat Aug 18, 2012 11:51 am
a long stroke motor can wind , my friends shop did a 421 for a super late , the driver had a SB2 in it before ,, they wound it to 8800 for 3 races , not the best idea , but its still together ,, if it had a cam that would pull that high , it would be a monster
levisnteeshirt
Postby sjvalleydave » Sat Aug 18, 2012 12:05 pm
We have a 421" SB2.2 in a DLM and run it 8400 all the time...
sjvalleydave
Postby bigjoe1 » Sat Aug 18, 2012 12:05 pm
Rod ratio is all bull shit. You can make anything work. Dont loose any sleep over it.
JOE SHERMAN RACING
bigjoe1
Show Guest
Show Guest
Postby jmarkaudio » Sat Aug 18, 2012 12:16 pm
I'd use a 4'" stroke.
Mark Whitener
____
jmarkaudio
Postby BigBro74 » Sat Aug 18, 2012 1:20 pm
bigjoe1 wrote:Rod ratio is all bull shit. You can make anything work. Dont loose any sleep over it.
JOE SHERMAN RACING
^^^^^^^Yes! ilike the way Big Joe Tells it.
BigBro74
Next
Return to Engine Tech
Who is online
Users browsing this forum: automotive breath, Bing [Bot], clueless, Google [Bot], Majestic-12 [Bot], Steve Salesky, turbomad and 8 guests
