mystic1582 wrote:I'm considering using a narrow bearing,; one I'll machine down myself that will live in a 2.100" small block Chevy motor approx 450hp max 6000-6500 rpm max. By machine down I mean make narrower by anywhere from .1" to .2" I can't use a 1.888 bearing (Honda) due to rules. Is there any merit to having less contact area versus less rotational feet per minute of surface area?
Thx
A 229cid Chevrolet V6 has a 2.100" rod throw and a bearing only .713" wide vs. a late small block Chevy at .842" wide.
I don't know your rules however, early small block Chevy's came with a 2.000" rod journal and there are several different width bearings available for that size.
A smaller size journal also has much less oil "throw-off" because of the area AROUND the journal..
