Erland Cox wrote:How do steeper seats than 45 degrees work in an endurance engine?
How much more often must the seats and valves be freshened with 50 or 55 degrees?
Does 50 degrees wear out much faster than 45 degrees?
Erland
Joel Dubose wrote:. I thought that this would be a quick and simple question that would save me some time.
I've decided to get a junk casting and go after it before doing anything to the race heads.
Erland Cox wrote:Can't you weld the bottom of the chambers to get the transition you want?
Erland
Joel Dubose wrote:Racers have been using 55* and 60* seats for many years. I have been using them for at least 15 years on longevity engines. Ie, NASCAR. Many company's have been using 50* seats on street engine . H D motorcycle, has been using them on there engine's. It's no secret to my knowledge. I'm going to be working on a pair of Ls style heads. I'm lifting them over an inch. It's a high rpm, high lift, drag race engine. I haven't worked on many of these heads. I thought that this would be a quick and simple question that would save me some time.
airflowdevelop wrote:which casting? I have used 60 degree seats on a number of them w/ great results.
rfl28 wrote:Joel Dubose wrote:Racers have been using 55* and 60* seats for many years. I have been using them for at least 15 years on longevity engines. Ie, NASCAR. Many company's have been using 50* seats on street engine . H D motorcycle, has been using them on there engine's. It's no secret to my knowledge. I'm going to be working on a pair of Ls style heads. I'm lifting them over an inch. It's a high rpm, high lift, drag race engine. I haven't worked on many of these heads. I thought that this would be a quick and simple question that would save me some time.
You must be related to JoePorting!.....
Users browsing this forum: Bing [Bot], brandonu, dcl, Jens.J, machinemark, Matt Gruber, motorking, Plaintoast, runawy9, veekuusi and 20 guests
