Mahle pro series pistons
Postby mnmatt » Wed Aug 15, 2012 6:28 pm
Has anyone used the Mahle pro series ASCS piston, if so how do they stand up?
Matt Hasara
mnmatt
Re: Mahle pro series pistons
Postby 1997bird » Wed Aug 15, 2012 7:08 pm
I haven't used the ASCS piston, but I have used the Mahle Professional series pistons before. They are a very nice piston and have never had a problem with using them.
1997bird
Postby mnmatt » Wed Aug 15, 2012 7:17 pm
Ok well I was just wondering because I am going to order a set but talked to a few guys and they said that theres some issue's with the dome cracking, I dont know if this is true or not because the only pro series I've worked with was a Sb2.2 or a flat top SBC 2bbl pin guided rod deal.
Matt Hasara
mnmatt
Postby Chris29 » Wed Aug 15, 2012 7:27 pm
I've used the pro series 4.130x 3.35 ascs in a super latemodel when I couldn't wait for a custom cp.I just freshened it and the pistons were in excellent shape after 2000 laps.I would use them again definately.
Chris29
Postby Hanzeng » Wed Aug 15, 2012 7:42 pm
I have never seen any piston of any brand 'crack' at the dome- there just aren't those type of forces there. I HAVE seen pistons start to come apart at the valve pockets if they were cut too deep without checking the thickness there, but I would have to say that the dome has the least stress out of any part of the piston.
Hanzeng
Postby Cogburn » Wed Aug 15, 2012 8:01 pm
I've used them, they are good. A few years ago some cracked in the strut area but it wasn't were it caused any problems and they had a lot of use(over 1200 laps in an ASCS sprint). You had to look VERY closely to find the cracks. The pins apparently were a little light and were flexing causing the crack according top MAHLE. I have heard of domes cracking for the same reason. The next set had pins that were a little heavier. They also were about the lightest available at the time and required very little dome rework.
Cogburn
Postby sprintracer » Mon Aug 27, 2012 5:08 pm
I just built a new ASCS sprint car engine the beginning of this year with the Mahle Pro Series ASCS Dome 4.125 bore piston. Have about 5 races so far, turning 8800 rpm. No issues yet! This motor made 730 hp on the dyno, and thats with their napier ring pack... Good Luck!!!
sprintracer
Return to Engine Tech
Who is online
Users browsing this forum: 77cruiser, bgr, Bing [Bot], Google [Bot], pmann and 9 guests
