wall thickness with full fill?
Re: wall thickness with full fill?
Postby Kevin Johnson » Thu Aug 16, 2012 3:44 am
cjperformance wrote:... Yes I like the idea of using modelling clay to make a water channel! I've used thin rubber hose before and pulled it out after the fill dries but never thought of clay!! how simple, thanks..
Another technique from the dental lab industry is to use wax. Similar products in use (grout/block-fill versus plaster/improved-stone). You can buy water soluble wax but I think utility wax rope would be easiest to work with. You will need to flush it out with boiling water, best laced with an emulsifier. Dental lab supply houses should have the wax and emulsifier.
Kevin Johnson
Postby JWebb » Thu Aug 16, 2012 4:32 am
Or carve out your shape in styrofoam as a plug, grout around it, and dissolve it out with brake clean.
JWebb
Previous
Return to Engine Tech
Who is online
Users browsing this forum: Bing [Bot], Buckwheat, coolchevy, Google [Bot], leahymtsps, Matt Gruber, RednGold86Z and 11 guests
