As you can see this is the final intake I will use on the engine. It will run with the foam socks you see on the pictures as filtration. The underhood cold air supply is standard vette 79 dual snorkel system (see picture).
My idea was to build a sort of plate above the manifold, which goes over the valve covers and attaches to the side of the valve covers. I would make an connection for the tube that goes to the cold air intake in the front and on the side for the right bank. Would probably make this in carbon, just to make it look a little nice.
What do you think. If you have a better idea, please post.
