latest results on overheating engine
Postby mike22l » Mon Jul 30, 2012 10:41 pm
I checked the car tonight. Heres what i found:
Water level is good. no lose.
I pulled no 7, 8 plug and they looked too clean and looked higly lean or the cylinders were not getting cooled by water and they got hot.
I pulled no 1, 2 plug and they looked perfect!
3 and 4 looked ok but slightly cleaner than 1 and 2 and 5 and 6 looked a little lean.
Seems we are getting hotter the more we go to the back. I suspect a bad waterpump would do this?
If the thing was low on fuel and running lean I would see it over all the plugs right? The plugs would read the same.
Maybe my fuel pump is going south and the front plugs look good because my 4412 carb is on a spacer that is pushed towards the front and feeding what fuels left to the front banks?
This is in addition to my warped vortec intake thread.....I machined everything and resealed it and i am not spitting water anymore. The rad level is perfect. My plugs are still getting too clean as i go towards the back of the engine.
I therefore suspect water pump is not pushing water in the back?
Your thoughts and thanks guys?
Mike
mike22l
Re: latest results on overheating engine
Postby mike22l » Mon Jul 30, 2012 10:43 pm
And this problem develped on a setup that always ran cool. Something went/is going south.
mike22l
Postby JoePorting » Tue Jul 31, 2012 2:19 am
You need to get the hot water in the rear of the motor to the front ASAP. The best way to do this is to plumb some water lines from the rear of the manifold to the front of the manifold just below the thermostat. You can either get a thermostat spacer with npt holes in them and plumb them there or just drill and tap two npt holes right by the thermostat.
Joe Facciano
joefacc1@yahoo.com
JoePorting
Postby Unkl Ian » Tue Jul 31, 2012 8:26 pm
Leaking head gasket ?
That would explain "too clean" on the plugs.
Just because you never studied the Laws of Physics,
doesn't mean they won't try to kick your ass.
Unkl Ian
Postby af2 » Tue Jul 31, 2012 8:38 pm
Unkl Ian wrote:Leaking head gasket ?
YEP
GURU is only a name.
af2
Postby mike22l » Tue Jul 31, 2012 9:11 pm
I just machined the heads flat and checked for cracks and checked the deck and put new gaskets on it thurs and before we ran it saturday.....and we are not using any water....
A leaking head gasket? On both sides? After a fresh cut and new gaskets? doubtful...
mike22l
Postby robert1 » Tue Jul 31, 2012 9:33 pm
Since I can't remember refresh my memory on the engine. For some reason I was thinking Ford. Give as much info as you can. When does it overheat, does it have a shroud, type of fan, water pump brand, compression, what head gaskets, fuel brand, how much timing, timing mark verified.
robert1
Postby mike22l » Tue Jul 31, 2012 9:47 pm
358 dirt circle track 358 chev
906 vortec heads
110 fuel
full shround with tunnelling
an old high flow summit water pump...yeah i know. yuck..its 5 years old...putting a new stewart stage 3 on tomorrow
11.6 :1
rpm 7116 intake
4412 carb
carter mechanical fuel pump
Never had an overheat problem before..something went south
We had an overheat problem 2 weeks ago because he got plugged with mud in the rad. Ran it the next week and it spit water everywhere and ran hot. Then we cut the heads and checked for cracks and cut the intake with new grade 8 bolts and torqued in 5 lb increments and verified intake fit. Deck is flat...Not spitting or losing water anywhere!
Theres lots of good ideas on how to keep it cool and run cooler...but...I had that...now i dont...hmmm...thoughts?
Putting on a new fuel pump and water pump tomorrow along with verifying carb spacer flatness with new gaskets.
You guys are great and I appreciate everyinput.
Mike
mike22l
Postby Unkl Ian » Tue Jul 31, 2012 9:48 pm
Unkl Ian
Postby mike22l » Tue Jul 31, 2012 9:49 pm
And timing mark verified running 34 deg...ran 34 last year and this year with no probs
mike22l
Postby mike22l » Tue Jul 31, 2012 9:58 pm
This one ?
viewtopic.php?f=1&t=31932&p=380622#p380622
Yes. That was the problem before we cut the heads and intake. Now we donet have a spitting losing water foamyness problem. Just a getting hot one.
mike22l
Postby robert1 » Tue Jul 31, 2012 10:05 pm
What brand of fuel, which head gaskets, what type of fan(4 blade GM) . The water pump is going to help.
robert1
Postby mike22l » Tue Jul 31, 2012 10:31 pm
Vp fuel
4 blade solid allstar
I think the water pump is a Summit high flow deal. I didnt buy it. The car owner did 5 years ago. Im putting on a new stewart stage 3
felpro 1003 head gasket
mike22l
Postby Chris29 » Tue Jul 31, 2012 11:43 pm
Get an adjustable carb spacer (canton or hvh) and slide the carb back and retry and jet accordingly.I have run into this with this combo before and thats what fixed ours.
Chris29
Postby Kevin Johnson » Wed Aug 01, 2012 3:57 am
Aluminum radiator?
viewtopic.php?f=1&t=31652&p=377102&hilit=aluminum+radiator+swell#p377041
Baprace wrote:Last but not least, if the radiator is aluminum and has been overheated it is probably no good, run your hand over the fins from top to bottom and if you feel any difference in the size of the fin meaning it has swollen then the heat dissapation ability is gone.
Kevin Johnson
Next
Return to Engine Tech
Who is online
Users browsing this forum: BT428, Cubic_Cleveland, donc, gramps, Hardcharger55, KRYPTINITE RACE ENGINES, Mr 408, PFC1, pmann, Ron E, sneukam, swatson454 and 15 guests
