Franco wrote:Ok I understand my heads are tired/used up whatever the case may be but I could still use some help. I had a few thou taken off the deck to clean it up and the seats touched up and replaced all the intake valves due to one being "stretched/tuliped" whatever its called. Intake valve lost lash. Checked all springs and pressure tested heads and replaced all 4 intake valves with new AFR argentina valves as its the only shelf valve available.
Went to the track and went back to the old safe tune up it ran reliably on and lost lash on all 4 new intake valves on the third pass. Plugs looked good no signs of detonation crazy heat or lean.
The valves in the other head seem to be fine no change in lash etc. What is causing this issue ?
Franco wrote:... replaced all the intake valves due to one being "stretched/tuliped" whatever its called.
rookie wrote:Franco wrote:Ok I understand my heads are tired/used up whatever the case may be but I could still use some help. I had a few thou taken off the deck to clean it up and the seats touched up and replaced all the intake valves due to one being "stretched/tuliped" whatever its called. Intake valve lost lash. Checked all springs and pressure tested heads and replaced all 4 intake valves with new AFR argentina valves as its the only shelf valve available.
Did you reset them to see if they would stabilize?
How much did they lose?
I always check mine several times on a fresh or rebuild the first night out until I know they are stable.
TMSJoe wrote:Franco wrote:... replaced all the intake valves due to one being "stretched/tuliped" whatever its called.
A tuliped intake valve IS a sign of detonation. I see this on boats all the time.
Are you checking and repairing both heads or just one side? All new intakes...... lost lash in all 4...? So you only have one head off I assume? Are they both the same chamber volume?
Franco wrote:As far as chamber volume they have been surfaced equally as far as I know.
Franco wrote:Put some valves in the other car recently and they also became paper weights in just a few runs. I found some humor in the situation when the new valves showed up with made in argentina crossed out.
Maybe it would be easier to just ship them without the bag instead of having someone cross them out.
Engguy wrote:
This is not good. Another case of trying to save a buck, but costing upwards to many many thousands more. AFR FROM ARGENTINA? If they get valves from there what else comes from there? This changes my positon on AFR. I hope DART doesn't do the same stupid stuff.
AFR if you want to out source to a different country try Germany or Japan.
Users browsing this forum: automotive breath, BlitzA64, BrazilianZ28Camaro, c4mo, coolchevy, dieselgeek, jim_ss409, Majestic-12 [Bot], mtkawboy, Steve439, USMC_Spike, wallbrett and 19 guests
