Compression ratio for bracket racer
Re: Compression ratio for bracket racer
Postby RichardThiessen » Tue Jun 19, 2012 7:43 pm
High compression and big cams hide deficiencies.... little surprised they went to the extreme of 16.5:1 though... especially if they did it on purpose. Maybe 14.5:1.
RichardThiessen
Postby MPac » Tue Jun 19, 2012 7:46 pm
If the pistons where hitting the heads like you said that would make me want to look through the valve train also cause I would think vavles where probably hitting too. I am by no means an expert like you Joe. It's just a thought.
matters not whether you win or lose; what matters is whether I win or lose
MPac
Postby D.S.R.E. » Tue Jun 19, 2012 7:49 pm
16.5? wow! Did you measure the Cranking compression by chance? Thats Wayyy too advanced!
D.S.R.E.
Postby raynorshine » Tue Jun 19, 2012 8:57 pm
af2 wrote:
SupStk wrote:After 13.5/1 gains get smaller and the problems become bigger.
I have wondered how much is left behind with the alcohol crowd wanting and running in the 15:1 area with 355 and 23 heads with that big dome/dam in the way.
me too, wish i said that :oops:
raynorshine
Postby Bucky » Wed Jun 20, 2012 9:15 am
I wonder if they stuck that cam in there advanced because they were having some p to v issues. Obviously the dome needs to come down or be reshaped to not hit the head, but maybe a flycut would be in order also tomake sure there is plenty of room for different cams put in at different positions. Just a thought.
I am currently running a tad over 14:1 on alky, and the engine seems to like it. I ran a tad over 13:1 for years on alky, and all was fine. I do think some of my gains when I updated my combo are from the extra compression. It may seem obvious, but when you talk alky and compression ratio, you can't overlook the cam. A big cam will of course in general like a bit more compression to work ideally. I don't think there is any right or wrong answer for compression ratio with alky. I have seen 12:1 and 15:1 work well.
Bucky
Postby Keith Morganstein » Wed Jun 20, 2012 9:23 am
I think very high compression is overrated. Something a bit over 13:1 is fine for racing gas engines and little less than that with a crappy chamber.
"Nil Satis Nisi Optimum"
Keith Morganstein
Postby Mark O'Neal » Wed Jun 20, 2012 10:04 am
10:1 is fine for a bracket racer. He's running a number.
Mark O'Neal
Postby lun40119 » Wed Jun 20, 2012 11:15 am
mach9 wrote:Keep us posted on the results after you fix it Joe. I bet you'll wake her up!
Of course he will..........Duh!!! Why do you think he started a thread.
Joe.........bracket motor........Id go pump gas..........like Mark said, he is only running a number. ;)
Jake
The Other 9 second SB/NA Car.......
3V Performance 23º Pumpgas 402
http://www.youtube.com/user/excedrin67? ... 1Tff2or1oY
1st Place Drag Week 2012 SB/NA
2nd Place Drag Week 2011 SB/NA
lun40119
Postby revolutionary » Wed Jun 20, 2012 11:19 am
He could always run it at Denver...
Daryl
Revolutionary Performance and Machine
revolutionary
Postby john@bmp » Wed Jun 20, 2012 12:00 pm
Something seems wrong....700 Seems awfully light for that engine. Joe, when you get it all fixed up let us know what it is, so we can file that away in the crevices of my eroding brain.
john@bmp
Postby sjvalleydave » Wed Jun 20, 2012 12:09 pm
We are a tad under 15:1 on race gas, but since we are doing this with flat top pistons we aren't really leaving anything out there, you think?
sjvalleydave
Postby Bucky » Wed Jun 20, 2012 2:01 pm
We don't build race engines to just run the number. Racers like to go fast too!
Bucky
Postby af2 » Wed Jun 20, 2012 9:45 pm
You think he might be running an INDEX ##? :?:
GURU is only a name.
af2
Postby rustbucket79 » Wed Jun 20, 2012 10:57 pm
Mark O'Neal wrote:10:1 is fine for a bracket racer. He's running a number.
With that theory it's a wonder why there aren't more of us running Pontiac Fireflys. :roll:
When I started bracket racing in 1991, there were a pile of us running 14's, and it was fun. Those of us still racing today that raced back then, are running the same cars, with different powerplants. The bulk of us are running 10's, with some of us knocking on the 9 second door. Most of us are running race gas, the rest are running premium with a Snow system. I gladly pay the money for VP 113, it's peanuts compared to the cost of everything else associated with racing, and I prefer to run quicker rather than slower. :mrgreen:
rustbucket79
Postby MELWAY » Wed Jun 20, 2012 11:16 pm
HAHA might be peanuts for you guys,,,,,we pay 220-250 dollars for 5gallons of Q16
MELWAY
PreviousNext
Return to Engine Tech
Who is online
Users browsing this forum: Adger Smith, BlitzA64, CNC BLOCKS, dazaifu, Exabot [Bot], frasse, Gary Evans, Google [Bot], Jens.J, POS Dakota, Racing68 and 30 guests
